Gen 3: 2008-2010 Shift Rod Replacement Question - Kawasaki ZX-10R.net
post #1 of 2 Old 10-30-2017, 05:05 PM Thread Starter
Hey so I have read everything I can and have ordered all of my parts.
I went to install everything and i can't get the ratchet and pawl assembly to function correctly.
Is the drum that the ratchet and pawl assembly connect to supposed to rotate when you move the shift rod back and forth?
Mine doesn't move at all and moving the shift rod back and forth effectively does nothing at all.
zx10rnoob is offline
post #2 of 2 Old 10-31-2017, 02:48 AM
michael4012's Avatar
If your meaning of moving the shift rod back & forth is you trying to change gear? Presuming the rear wheel is off the ground & your turning the wheel as you try to change gear & it's not changing then I would say either you'v not assembled it correctly or the reason for changing the rod isn't actually the rot problem. Have you pictures of it as is & more information please.
michael4012 is offline
Gen 3: Question on custom length shift rod enrico vespa Performance and Tech 7 08-05-2013 06:02 PM
Go to shift, no shift rod in site. customspeed The Out House 5 03-02-2010 10:34 PM
NEEDED - shift rod... Fixer Wanted: Buy or Trade 11 05-02-2009 11:30 PM
Longer shift rod? Help! lunitk The ZX-10R 6 07-25-2008 01:22 AM
Shift rod teck Performance and Tech 0 04-06-2008 04:49 AM
