Kawasaki ZX-10R.net
Kawasaki ZX-10R.net (https://www.zx-10r.net/forum/)
-   The ZX-10R (https://www.zx-10r.net/forum/f23/)
-   -   Gen 3: Shift Rod Replacement Question (https://www.zx-10r.net/forum/f23/shift-rod-replacement-question-343297.html)
zx10rnoob 10-30-2017 05:05 PM
Hey so I have read everything I can and have ordered all of my parts.
I went to install everything and i can't get the ratchet and pawl assembly to function correctly.
Is the drum that the ratchet and pawl assembly connect to supposed to rotate when you move the shift rod back and forth?
Mine doesn't move at all and moving the shift rod back and forth effectively does nothing at all.
michael4012 10-31-2017 02:48 AM
If your meaning of moving the shift rod back & forth is you trying to change gear? Presuming the rear wheel is off the ground & your turning the wheel as you try to change gear & it's not changing then I would say either you'v not assembled it correctly or the reason for changing the rod isn't actually the rot problem. Have you pictures of it as is & more information please.
Powered by: vBulletin Version 3.8.8
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©2003-2015 ZX-10R.net
