Gen 1: 2004-2005 Ride Height after Swingarm Swap - Kawasaki ZX-10R.net
post #1 of 6 Old 08-13-2018, 10:38 AM Thread Starter
Hi everyone, I have recently purchased a Gen 3 swingarm to swap onto my Gen 1, since the original has a dent in it. I have been reading about the swap, and people have reccomended I use 05/06 linkages. Does this put the bike at the stock ride height? How will this affect the handling? I would rather keep the stock swingarm if this swap will negatively affect the handling of the bike. Can anyone with experience riding with this setup please give some feedback? Thanks.
Lilbilly is offline
post #2 of 6 Old 08-13-2018, 11:16 AM
10roller's Avatar
the rear will sit higher than stock even with the swapped linkage. if i remember correctly, for me i believe i was +8mm in the rear with the shim for the rear shock removed. you will definitely feel the difference when sitting on the bike, more of your weight on the clip-ons. try it out, takes less than a day to swap a swingarm.
https://www.zx-10r.net/forum/f28/05-...arm-63771.html
10roller is offline
post #3 of 6 Old 08-13-2018, 11:53 AM Thread Starter
Handling
Oh ok I see, thanks! Do you feel like it was a handling improvement, or did it feel wierd? Would you do the swap again? Did you ever take it to the track? Sorry for all the questions haha.
Lilbilly is offline
post #4 of 6 Old 08-13-2018, 11:55 AM Thread Starter
Handling
Lilbilly is offline
post #5 of 6 Old 08-13-2018, 04:19 PM Thread Starter
Shock
What rear suspension did you use? Stock or 3rd gen?
Lilbilly is offline
post #6 of 6 Old 08-14-2018, 02:32 AM
10roller's Avatar
i feel like it was a little too high in the rear. i would do the swap again but try to get the rear a little lower.
10roller is offline
Tags
gen 1, swingarm
Gen2 unever fork height after seals USCG_zx10r Suspension and Tire Tech 13 07-27-2016 03:44 PM
Ride Height Adjuster or Higher Heels? Iculukn The ZX-10R 30 04-25-2013 10:31 PM
Another swingarm swap question... 1st gen to 2nd gen swap RITCHYRITCH The ZX-10R 2 10-21-2009 03:05 PM
Ride Height Spacers, where to buy? gladding24 Performance and Tech 12 10-15-2004 08:25 AM
Ride Height Adjustment??? JLove The ZX-10R 6 05-03-2004 07:02 PM
