Gen 2: 2006-2007 Removing clutch basket - Kawasaki ZX-10R.net
 7Likes
post #1 of 18 Old 10-28-2018, 10:22 PM Thread Starter
Sasquatch's Avatar
Is there a trick to removing the clutch basket on a 2nd gen? I've pulled the bearing and the sleeve. I've still not got enough room to pull the basket or I've missed something somewhere.
As long as I'm starting a thread, I'm looking for a knock that sounds like it's in the clutch. It's been slowly getting louder over the years. I was expecting to find a basket with loose rivets. So far, I can't tell. The basket did slide a fair bit in and out. Maybe that means something.
06 10r with 35k on the clock. Never raced, no clutch ups, no abuse since purchasing used in 08.
Have a wheelie nice day!
Winter sucks.
Sasquatch is offline
post #2 of 18 Old 10-29-2018, 01:09 AM
michael4012's Avatar
Do you mean the roller needle bearing and sleeve from the center of the flywheel??? if you have done all of that then with a pull outward dropping the wheel down and left onto the shaft it should come out wiggling bottom left out first, can you post a picture?
michael4012 is offline
post #3 of 18 Old 10-29-2018, 02:55 AM
Battlax Bunny's Avatar
Sounds maybe silly, but is a crankshaft lobe blocking the removal of your clutch basket? On a gen 4 this can happen.
SkyDork, Kawasaki Brad and gaz like this.
Battlax Bunny is offline
post #4 of 18 Old 10-30-2018, 12:40 PM Thread Starter
Sasquatch's Avatar
https://youtu.be/NHRt91PFlfU
Basket
https://youtu.be/q6gQ9h3TEBI
noise. Now I'm wondering if it's up top and I had it wrong all along
Winter sucks.
post #5 of 18 Old 10-30-2018, 02:08 PM
SkyDork's Avatar
Basket
Yo! Spin the crank to TDC! the basket is interfering with the #4 connecting rod because it's not at TDC or BDC. You can kind of see that in the video of the flywheel being constrained. Rotate the crank to make it clear. The basket should come right off.
#WordCrimes
SkyDork is offline
post #6 of 18 Old 10-30-2018, 03:00 PM Thread Starter
Sasquatch's Avatar
Oh, for crying out loud. I was in such a hurry to get this done that I completely forgot to set TDC. Thanks for the tip.
Winter sucks.
post #7 of 18 Old 10-30-2018, 03:45 PM
SkyDork's Avatar
Yeah, don't beat yourself up over a simple mistake like that. That's our job as forum members! I mean...to help you out, not beat you up over it.
#WordCrimes
SkyDork is offline
post #8 of 18 Old 11-01-2018, 12:56 PM Thread Starter
Sasquatch's Avatar
Evidently, it's not a silly suggestion at all. You were 100% correct. Thanks!
That's what I'm afraid of!
The basket and associated parts are all good. I've got troubles elsewhere. As time allows, I'll poke around further and update this thread. I appreciate the help/suggestions.
ETA I'm a big fat liar. Evidently, the basket is NOT good. The springs in the back are mostly loose. They're supposed to have a bit of preload on them per a local independent shop. The rivets are fine, and that was what I thought would be bad. Furthermore, there are the beginnings of grooves on the basket from the clutch plates. Initially, I thought they were nothing more than marks. With my fingernail, I can feel them. Sooo...... This is going to cost me a bit of money. I'll see if I can even get a stock basket and hope this solves the noise issue.
Winter sucks.
post #9 of 18 Old 11-21-2018, 02:09 PM Thread Starter
Sasquatch's Avatar
I'm finally getting around to putting this thing back together. The 4 torque limiter springs need to be assembled correctly. Does this look right?
Winter sucks.
post #10 of 18 Old 12-13-2018, 12:12 PM Thread Starter
Sasquatch's Avatar
I may be talking to myself at this point. Gen2 ZX10s are mostly extinct-I can't remember the last time I saw one on the road. In the event that someone stumbles upon this in a search one day, I'm going to keep updating the thread.
The bad clutch basket advice that I was given was absolute horseshit. He may have genuinely believed that's what it was-but it wasn't.
That annoys me double because I spent money I don't have on parts I didn't need. Now I'm going to have to spend more money that I don't have to dive deeper.
I can't even sell the thing with this noise unless I give it away. Heck, even in top shape, it's a high mileage almost 13 year old bike. I won't see much money from it anyway.
The old lady got a bit stern with me last night when I talked about selling. "We can't afford a new one and you can't be without a bike, so you have e to fix this." Ha! Like I needed another reason to know she was the right woman for me!
Winter sucks.
Gen 3: WTB: Clutch Basket, clutch assembly, housing tvor Wanted: Buy or Trade 5 03-06-2012 02:47 PM
Removing Clutch Basket nut Luiz_Direito General Motorcycle Discussions 19 01-09-2012 11:03 AM
What size is the clutch basket nut? 1FatNinja Performance and Tech 12 03-02-2007 01:04 PM
Will 03-04 ZX-6RR clutch basket fit in the ZX-636 same year? BrianRacerboy ZX-6R & ZX-6RR Archives 3 12-17-2006 08:42 PM
06 clutch basket problems TX06'10r Performance and Tech 15 10-25-2006 03:34 PM
