Race season over distilled water or coolant - Kawasaki ZX-10R.net
 3Likes
post #1 of 11 Old 11-07-2019, 07:18 PM Thread Starter
Ghettochilds's Avatar
Appolisge in advance if this topic has been brought up previously.
So as the topic goes my race season is over and my Gen 2 is being stored in the bricked garage (no heating).
So part of ACU regs is that you need to be running distilled water during races for obvious reasons.
Now that the festive season is around the corner and the motorcycle is being stored away until April next year.
Is there really any need to flush the system out and replace it with coolant. Then flush the system out and replace with distilled water again.
I live in the United Kingdom and the coldest winter we reached was -7 degrees to -5 degrees.
Your wise wisdom is much appreciated as I've come across a few threads commenting on engine blocks/rads cracking.
Thanks 🏼
Ghettochilds is offline
post #2 of 11 Old 11-07-2019, 08:18 PM
The Prophet's Avatar
Considering water freezes at 32f, I would say yes use coolant 50/50 mixture. I would run it for a bit as well to lube up the water pump and coat the internals for the winter.
The Prophet is offline
post #3 of 11 Old 11-07-2019, 09:20 PM
Bottoms-Up's Avatar
or in in Ghetto's case, water freezes at 0 degrees .
You just drain it.
Need to drain or add "Anti-Freeze"
CanyonCarver likes this.
Bottoms-Up is offline
post #4 of 11 Old 11-08-2019, 07:16 AM Thread Starter
Apologies*
post #5 of 11 Old 11-08-2019, 07:28 AM
ShawnG's Avatar
I just drain my water out for the winter. lean it over a few times to get the extra water and leave the drain plug out. Has been fine for me and i live in Michigan were it also gets well in the negative temps during winter.
ShawnG is offline
post #6 of 11 Old 11-08-2019, 08:46 AM
gaz
some of the engines i build i run a distilled water/coolant lowering addative in the summer months on my customers bikes. just called three of them this week to remind them to drain and refill with antifreeze for cold weather coming. so yeah, definatley change to antifreeze solution.
Kawasaki Brad likes this.
gaz is offline
post #7 of 11 Old 11-08-2019, 01:23 PM
Kawasaki Brad's Avatar
It gets down to -40 here so us damn Canadians have a lot of experience dealing with cold.
50/50 mix of antifreeze and distilled water is what you need. The glycol in the antifreeze keeps it from freezing, and the anti corrosive additives keep it from corroding. Simply drain the existing coolant and replace with this stuff. Top up the reservoir, let it run for a few minutes, and you're done.
"Tipping the bike over a couple times" does not get ALL the water out of the pump or water jacket of the engine. That doesn't work at all and being someone who runs a parts desk at a local dealership I sell quite a few rads and water pump covers due to that horrible advice. It will still freeze and crack. Please don't do that. Plus if you leave your coolant system empty you will accelerate corrosion while drying out your seals.
Your track tech won't want to see glycol in the spring (if you crash and it leaks it's super slippery and a b!tc# to clean up) so when the risk of freezing subsides drain out the glycol mix and replace it with whatever you're running now.
gaz likes this.
Kawasaki Brad is offline
post #8 of 11 Old 11-08-2019, 01:59 PM Thread Starter
Absolutely appreciate all your advices.
I just knipped out and picked up 3ltrs of Silkolene Mag Cool preferred the Castrol stuff but that wasn't around.
Felt the toolbox flipping cold as ever. Can't have the bike sitting like that even if it's just for 1 night.
post #9 of 11 Old 11-08-2019, 02:02 PM
Bottoms-Up's Avatar
Originally Posted by Kawasaki Brad View Post
It gets down to -40 here so us damn Canadians have a lot of experience dealing with cold. 50/50 mix of antifreeze and distilled water is what you need.
If you have a chance of seeing temps -40, you probably need to mix your antifreeze 60/40 or more.
Check manufactures chart for ratio.
post #10 of 11 Old 11-08-2019, 03:11 PM
michael4012's Avatar
For sure using anti freeze is a smart move. You may not be racing but you want to starting that bike every couple of weeks let it run up to temp then turn het off. Prolonged cold is bad on internal springs and the shell bearings suffer icy the oil isn't freshened up by regular starting. And the additives in the coolant have a lubricating and cleansing effect leaving the system in better condition when you drain out for the new season.
michael4012 is offline
