pulling to the right (08) - Kawasaki ZX-10R.net
post #1 of 24 Old 05-14-2008, 09:42 PM Thread Starter
spikespiegel's Avatar
Send a message via AIM to spikespiegel Send a message via Yahoo to spikespiegel
I tried searching but haven't found anything (the search is pretty horrible) but i just checked and the bike DOES pull to the right when i take my hands off the bars and sit back on the seat... WTF is up with that? Anyone have any ideas as to why its doin that?
spikespiegel is offline
post #2 of 24 Old 05-14-2008, 09:46 PM
omar's Avatar
Check your tire pressure. Same thing happened to me on my 06. Good luck
omar is offline
post #3 of 24 Old 05-14-2008, 09:52 PM
ZX-10R_Sinner's Avatar
Forks aren't true maybe or the rear tire isn't adjusted straight...
I believe JJ and maybe a few others have said that their forks came twisted a little from the factory and they had to loosen up the triple clamps to straighten them. Check your alignment marks on the swingarm, if they're both really close or the same I'm not sure how much of an impact that would have.
ZX-10R_Sinner is offline
post #4 of 24 Old 05-14-2008, 09:54 PM Thread Starter
err my tire pressure is fine, i check it weekly, and the notches on the swingarm on both sides are dead equal, i make sure i always adjust those as accurately as possible.. Will check out the forks .
post #5 of 24 Old 05-14-2008, 09:57 PM
bkkninja's Avatar
you could try and loosen the front axle nut and then bounce on the front forks hard. To make sure all is align and parrallel. remember to retorue it before you take it out for a ride. Check rear wheel alignment as well. These are only possibilities.
BKK
bkkninja is offline
post #6 of 24 Old 05-17-2008, 03:58 PM
YZF
BANNED
Which one is front axel nut ? Those two, one at right fork and one at left? (Number 3 on first picture) Or center steering nut? (Number 7 on second picture)
ID:	68707   Click image for larger version
YZF is offline
post #7 of 24 Old 05-17-2008, 04:09 PM
wuzupez's Avatar
I was just logging on to put up a post about the same exact thing. I have an 07 that has been doing the same this since I bought it. It was a leftover I bought 3 months ago with 0 miles. It has done this since day 1 & I now have 650 miles on it. But mine even pulls to the right upon hard acceleration or stand up wheelies. I have adjusted tire pressure, aligned the rear wheel so it is exact from side to side. It's driving me crazy. My one friend tells me it's just me & it's all in my head which it clearly isn't. Any help or info would be great!
06 10r/08 kfx 450r
wuzupez is offline
post #8 of 24 Old 05-17-2008, 04:17 PM
MIA Ex-Mod
Tread70's Avatar
If you are sure your rear is aligned, measure from the swingarm pivot bolt to rear axle on each side and verify they are the same. Sometimes the tick marks on the swingarm are off.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #9 of 24 Old 05-17-2008, 04:18 PM
MIA Ex-Mod
Tread70's Avatar
The axle nut is the one that goes thru the wheel not up on the triple trees.
Tread
Tread70 is offline
post #10 of 24 Old 05-17-2008, 04:18 PM
wuzupez's Avatar
The axle nut is what holds the wheel on! Hey, does your bike only pull to the right when your coasting with hands off the bars or when you role onto the throttle does it pull as well? This has been driving me nuts. When I drag race I have almost my entire body hnging off the laft side of the bike to try & correct the pull.
06 10r/08 kfx 450r
wuzupez is offline
Front Pulling To The Right !! 10 nw ga. Performance and Tech 19 05-11-2008 07:09 PM
Pulling the Trigger!! BD or Deez Katoom? Kwaky Performance and Tech 6 08-01-2007 02:18 PM
Update on pulling the girl out of storage 06Neenja The ZX-10R 0 12-31-2006 08:55 AM
Pulling out my hair [email protected] Performance and Tech 10 09-04-2006 12:17 PM
Bike on dyno pulling some big numbers toedragger24 Pictures and Videos 9 12-27-2005 12:53 PM
