Here's the codes list for the Gen3-
Self-Diagnosis
Service Code Table
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction (Equipped Models)
36 Blank Key detection (Equipped Models)
39 ECU communication error
46 Fuel pump relay malfunction, relay is stuck
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater #1 and/or #2 malfunction, wiring open or short (Equipped
Models)
83 Oxygen sensor #2 inactivation, wiring open or short (Equipped Models)
Notes:
○The ECU may be involved in these problems. If all the parts and circuits checked out good, be sure
to check the ECU for ground and power supply. If the ground and power supply are checked good,
replace the ECU.
○When no service code is displayed, the electrical parts of the DFI system has no fault, and the
mechanical parts of the DFI system and the engine are suspect.
3-42 FUEL SYSTEM (DFI)
Self-Diagnosis
Backups
○The ECU takes the following measures to prevent engine damage when the DFI, ignition or immobilizer
system parts have troubles.
Service
Codes Parts Output Signal Usable
Range or Criteria Backups by ECU
11 Main Throttle
Sensor
Output Voltage
0.2 ∼ 4.8 V
If the main throttle sensor system fails (the
output voltage is out of the usable range,
wiring short or open), the ECU locks ignition
timing into the ignition timing at closed throttle
position and sets the DFI in the D-J method.
12
Inlet Air
Pressure
Sensor
Inlet Air Pressure
(Absolute)
Pv = 50 ∼ 910 mmHg
If the inlet air pressure sensor system fails
(the signal is out of the usable range, wiring
short or open), the ECU sets the DFI in the
α-N method (1).
13
Inlet Air
Temperature
Sensor
Inlet Air Temperature
Ta = – 30 ∼ + 100°C
If the inlet air temperature sensor system fails
short or open), the ECU sets Ta at 30°C.
14
Water
Temperature
Sensor
Water Temperature
Tw = – 30 ∼ + 120°C
If the water temperature sensor system fails
short or open), the ECU sets Tw at 80°C and
the radiator fan operates.
15
Atmospheric
Pressure
Sensor
Atmospheric Pressure
(Absolute)
Pa = 50 ∼ 910 mmHg
If the atmospheric pressure sensor system
fails (the signal is out of the usable range,
wiring short or open), the ECU sets Pa at 760
mmHg (the standard atmospheric pressure).
21 Crankshaft
Sensor
Crankshaft sensor must
send 22 signals to the ECU
at the 1 cranking.
If the crankshaft sensor fails, the engine stops
by itself.
23
Camshaft
Position
Sensor
must send 1 signal to the
ECU at the 2 crankings.
If the camshaft position sensor system fails
(the signal is missing, wiring short or open),
the ECU continues to ignite cylinders in the
same sequence following the last good signal.
However, it can not be restarted after the
engine was stopped once.
24 Speed
Sensor
Speed sensor must send
30 signals to the ECU at
the 1 rotation of the output
shaft.
If the speed sensor system fails (no signal,
wiring short or open), the speedometer shows
0.
25
Gear
Position
Switch
Output Voltage
0.2 ∼ 4.8 V
If the gear position switch system fails (no
signal, wiring short or open), the ECU set the
top (6th) gear position.
31
Vehicle
-down
Sensor
Output Voltage
0.2 ∼ 4.8 V
If the vehicle-down sensor system has failures
(the output voltage is out of the usable range,
wiring short or open), the ECU shuts off the
fuel pump relay, the fuel injectors (primary and
secondary) and the ignition system.
32 Subthrottle
Sensor
Output Voltage
0.2 ∼ 4.8 V
If the subthrottle sensor system fails (the
output voltage is out of the usable range, wiring
short or open), the ECU drive the subthrottle
valve to the full closed position, and it stops
the current to the subthrottle valve actuator.
FUEL SYSTEM (DFI) 3-43
Self-Diagnosis
Service
33
Oxygen
Sensor #1
(Equipped
Models)
The oxygen sensor #1 is
active and sensor must
send signals (output
voltage) continuously to
the ECU.
If the oxygen sensor #1 is not activated, the
ECU stops the feedback mode of the oxygen
sensor #1 and #2.
34
Exhaust
Butterfly
Valve
Actuator
Sensor
Output Voltage
0.2 ∼ 4.8 V
If the exhaust butterfly valve actuator sensor
system fails (the output voltage is out of the
usable range, wiring short or open), the ECU
drive the exhaust butterfly valve at full open
position near, and it stops the current to the
exhaust butterfly valve actuator.
35
Immobilizer
Amplifier
(Equipped
Models)
– If the immobilizer system fails (no signal, wiring
short or open), the vehicle is no start and run.
36
Master or
User Key
(Equipped
Models)
The user or master key
must use register key.
If the blank key or broken key is used, the
39 ECU
The ECU send the data
(for gear position, service
code and key registration)
to the meter unit.
46 Fuel Pump
Relay
When the relay ON
condition, battery monitor
voltage 5 V or more
51 Stick Coil #1*
The stick coil primary
winding must send
signals 32 or more times
continuously to the ECU.
If the stick coil #1 primary winding has failures
(no signal, wiring short or open), the ECU
shuts off the injector #1 to stop fuel to the
cylinder #1, though the engine keeps running.
52 Stick Coil #2*
winding must send
If the stick coil #2 primary winding has failures
shuts off the injector #2 to stop fuel to the
cylinder #2, though the engine keeps running.
53 Stick Coil #3*
winding must send
If the stick coil #3 primary winding has failures
shuts off the injector #3 to stop fuel to the
cylinder #3, though the engine keeps running.
54 Stick Coil #4*
winding must send
If the stick coil #4 primary winding has failures
shuts off the injector #4 to stop fuel to the
cylinder #4, though the engine keeps running.
56 Radiator Fan
Relay
When the relay OFF
condition, the fan relay is
open.
62
Subthrottle
Valve
Actuator
The actuator operates
open and close of the
subthrottle valve by the
pulse signal from the ECU.
If the subthrottle valve actuator fails (the
signal is out to the usable range, wiring short
or open), the ECU stops the current to the
actuator.
3-44 FUEL SYSTEM (DFI)
Self-Diagnosis
Service
63
Exhaust
Butterfly
Valve
Actuator
exhaust butterfly valve by
the pulse signal from the
ECU.
If the exhaust butterfly valve actuator fails (the
actuator.
64 Air Switching
Valve
The air switching valve
controls the flow of the
secondary air by opening
and shutting the solenoid
valve.
67
Oxygen
Sensor
Heater #1
and/or #2
(Equipped
Models)
The oxygen sensor
heater #1 and/or #2 raise
temperature of the sensor
for its earlier activation.
If the oxygen sensor heater #1 and/or #2 fails
(wiring short or open), the ECU stops the
current to the heater, and it stops the feedback
mode of the oxygen sensor #1 and #2 .
83
Oxygen
Sensor #2
(Equipped
Models)
The oxygen sensor #2 is
the ECU.
If the oxygen sensor #2 is not activated, the
ECU stops feedback mode of the oxygen
sensor #1 and #2.
Note:
(1) α-N Method: the DFI control method from medium to heavy engine load. When the engine load
is light like at idling or low speed, the ECU determines the injection quantity by calculating from the
throttle vacuum (inlet air pressure sensor output voltage) and engine speed (crankshaft sensor output
voltage). This method is called D-J method. As the engine speed increases, and the engine load turns
middle to heavy, the ECU determines the injection quantity by calculating from the throttle opening
(main throttle sensor output voltage) and the engine speed. This method is called α-N method.
*: This depends on the number of stopped cylinders
