Gen 4: 2011-2015 Proper clutch replacement and oil - Page 2 - Kawasaki ZX-10R.net
 4Likes
post #11 of 16 Old 01-18-2017, 08:39 PM
zx racer's Avatar
Originally Posted by ShawnG View Post
I couldn't figure out if cycle concepts clutch pack still required those springs?... think i might have left them out. so just to be sure the cycle concepts clutch pack still requires those springs?
You should be fine with stock springs. Dewayne sells his clutch kits with or without the springs.
Sent from my SCH-I545 using Tapatalk
05 ZX-10R SWB.
zx racer is offline
post #12 of 16 Old 01-19-2017, 09:25 AM
C3L1CA's Avatar
I've always put those springs back in when I've used his clutches, but honestly not sure if they are needed. I always put them in because that is what is shown in the manual. I'm sure Dwyane at Cycle Concepts could answer that question for sure though.
C3L1CA is offline
post #13 of 16 Old 01-19-2017, 01:09 PM
ShawnG's Avatar
thanks for the input i will just give him a call. I gotta tear it back down any way... Thought it would be alright to "man" it out and run his stiffer springs with my track bike. That was a bad idea... After the day was done i dont think i could squeeze with any force in my left hand lol.
ShawnG is offline
post #14 of 16 Old 01-19-2017, 01:13 PM
ShawnG's Avatar
I was talking about those 2 rings that go in between the first set of steels. But yes i did run his stiffer clutch springs and man they are stiff haha. thought my fingers were going to fall off
ShawnG is offline
post #15 of 16 Old 01-19-2017, 01:19 PM
zx racer's Avatar
Oh k i would use the rings with his clutch. His springs are stiff as fk but there good to have to prevent clutch slipage.
ShawnG likes this.
05 ZX-10R SWB.
zx racer is offline
post #16 of 16 Old 01-19-2017, 01:20 PM
C3L1CA's Avatar
Lol yea his stiffer springs are pretty nasty but you'll eventually get used to them. I think I only have 3 though and 3 of the brocks HD ones. I rode my buddies gen 4 with stock springs last summer and at first thought something was wrong with his clutch since the clutch lever was sooooooo easy to pull in.
ShawnG likes this.
C3L1CA is offline
Gen 4: Proper sidestand/clutch sensor operation GILBY The ZX-10R 7 05-18-2014 11:51 AM
Gen 4: Clutch Replacement Bounce Performance and Tech 2 06-11-2013 12:44 PM
clutch replacement 10inja Performance and Tech 8 05-08-2007 12:37 AM
clutch replacement? Rob Mc Performance and Tech 0 02-01-2007 08:27 AM
Replacement Oil mods2come The ZX-10R 22 06-14-2004 10:06 PM
