Gen 4: 2011-2015 Powerband flat spot 3-5k rpms - Kawasaki ZX-10R.net
post #1 of 51 Old 09-14-2011, 02:46 PM Thread Starter
hi, i have a 2011 zx10r fully stock with 1100 miles.
traction control off
3-5k rpms
1-3 gears
if you punch full throttle quickly, there isn't any power until you hit about 6-8k rpms. its very obvious and feels as though you've been reduced to 30hp. once you hit 6-8k rpms, you get full power and the bike just explodes forward.
this happens about once in every 15 tries.
i've taken the bike to the dealership but they can't find a problem.
has anyone else had this problem?
thanks
steebypue is offline
post #2 of 51 Old 09-14-2011, 10:16 PM
Post Whore
Older Guy's Avatar
get rid of the muffler, put on a can, reflash the ECU by Guhl, install a Bazzaz, get a custom map and you're good....LOL
Older Guy is offline
post #3 of 51 Old 09-14-2011, 10:22 PM
09zx10miami's Avatar
Originally Posted by older guy View Post
get rid of the muffler, put on a can, reflash the ecu by guhl, install a bazzaz, get a custom map and you're good....lol
****Giiiiiiiiittttttuuuurrrdooonnneee****
09zx10miami is offline
post #4 of 51 Old 09-14-2011, 10:22 PM
I'm pretty sure ALL bikes bog like that when you punch it tha low in the rpm range? i know mine does and it's tuned right.
Two bros exhaust, pcIII, 16t front 42t rear, 1/5 throttle, ivans TRE, HID's,white LED running lights, complete underglow LED's, speedohealer, flies removed, nissins with ss lines, k&n filter
Originally Posted by Guyta View Post
Fuck that's hot, i wish god didn't make me ugly.
Vortec is offline
post #5 of 51 Old 09-15-2011, 02:24 AM
Post Whore
-Op-'s Avatar
my Gen 1 if you get to about 2.5k and punch it will lug for a second start to move through the revs and at 4.5k will really come alive. They just dont like going when youre that far down on the tach.
you can do the pipe suggestion. Id say the biggest thing would also be to get the flash. tuning will step it up too. maybe add a tooth on the rear?
-Op- is offline
post #6 of 51 Old 09-15-2011, 03:05 AM Thread Starter
the problem isn't lack of power at the wheel down low in the rpm range. there is definitely something wrong with the electronics.
in other words, if, instead of punching it at 3k, i roll on the throttle it'll accelerate as expected. it only bogs down when you punch it.
post #7 of 51 Old 09-15-2011, 04:01 AM
All show and all go 10r
JLG0987's Avatar
Nothing wrong, that's completely normal. Try doing that in anything you own.
JLG0987 is offline
post #8 of 51 Old 09-15-2011, 04:22 AM
My Gen 1 is the same, down low and you open it up, it feels like the rear wheel wants to brake of the bike and GO!!! Not very healthy to punch it at low rpm, wait til about 4.5 and klap it hard.
Regardt is offline
post #9 of 51 Old 09-15-2011, 05:05 AM
SBK X's Avatar
Yep Older Guy is spot on!
I had this issue and I found that the stock ECU has a bit of a low rpm fueling issue. I put my problem down to a poorly tuned TPS (Throttle Position Sensor) from factory but either way to bother re tuning you may as well do a pipe and filter while you are installing a new fuel computer (whatever brand) to gain some pony's at the same time.
It will make the bike better to ride across the whole rev range anyway so would be a worthwhile venture just not a cheap dealer fix.
Never know though they may release an updated stock ECU tune at some stage down the track.
SBK X is offline
post #10 of 51 Old 09-15-2011, 06:06 AM
BANNED
if you punch it at low rpms, the air doesn't have enough velocity and it will produce less power if you open it up gradually, every sport bike with rev limit over 10k rpm will do it
hellboytt is offline
2007 zx10 flat spot? topnotch Performance and Tech 2 08-30-2009 06:46 PM
Zx12 flat spot Need help zixxer General Motorcycle Discussions 0 02-19-2008 07:20 AM
When does your powerband hit? Zixxer2Go The ZX-10R 22 10-18-2006 02:09 PM
pc flat spot up to 4000rpm,help SUPER K Performance and Tech 17 05-05-2006 04:23 AM
flat spot on the 10r 05 Brendan ZX-10R The ZX-10R 62 09-11-2005 12:17 AM
