Power commander issue???? - Kawasaki ZX-10R.net
post #1 of 17 Old 01-14-2013, 10:05 AM Thread Starter
whans1980's Avatar
Just installed my PCV last week.. And did the spark plugs while I was there. This weekend was the first weekend I really had a chance to get some lengthy riding in. After riding for a while the bike looses power and it sounds like a dam Ducati. I think it is running lean. When it does it I cycle the key off and then start it and the issue is gone, but after riding for a little bit it will do it again.. At first I thought mabey the fuel line was pinched and it was intermittently starving for fuel but the fuel line looks fine. I was running a map that GSP gave me (me and his bike have almost identical mods), but the map he gave me was optimized w autotune so I thought mabey that had something to do with it. So I changed to a base map and it still did it.. Think im gonna take the PC out and try to run it again and then I will know for sure.. Was wondering if any of you have had this happen?
It is a 2012 with wire mod, k and n, m4gp slip on with baffle taken out, 16t in the front. The bike ran like a top before the PCV and plugs were installed, and runs great with the PCV when its not fucking up. Pretty sure the problem isnt with the plugs because cycling the key wouldnt do much to remedie an issue with plugs.
whans1980 is offline
post #2 of 17 Old 01-14-2013, 10:23 AM
yed
yed's Avatar
Are u using the latest firmware?
yed is offline
post #3 of 17 Old 01-14-2013, 10:40 AM Thread Starter
whans1980's Avatar
Yea, everything is current and updated
I think it has an intermittent short inside the pcv,
post #4 of 17 Old 01-14-2013, 11:02 AM Thread Starter
whans1980's Avatar
Just talked to tech support, they said try updating the firmware like 3 times,, they said sometimes it doesnt install all the right drivers.
post #5 of 17 Old 01-15-2013, 03:27 AM
yed
yed's Avatar
Then request for replacement
yed is offline
post #6 of 17 Old 01-15-2013, 06:10 AM
GSP
GSP's Avatar
Are you running win 7 on pc? if XP then it is problematic for the correct drivers and flash. Since you did plugs, I would disconnect all PCV connectors and ride to see what happens.
GSP is offline
post #7 of 17 Old 01-15-2013, 06:12 AM
GSP
GSP's Avatar
What version of firmware?
GSP is offline
post #8 of 17 Old 01-15-2013, 06:45 AM
I had the same problem with my PCV. The bike stalled on me in heavy traffic while doing 80 on the interstate. The shoulder was 3 lanes over and I had to cut cars off without the inability to turn the bike back on.
It's an intermittent dropped cylinder issue. Send the unit back and have it replaced. I bought a second unit and DJ overnighted it to me. I sent the defective unit and received a refund. They have great customer service and will help you out as much as they can.
Sent from my iPhone using Motorcycle.com App
mathom33 is offline
post #9 of 17 Old 01-15-2013, 07:23 AM Thread Starter
whans1980's Avatar
Win 7.. I did update the firmware when I first got it, and I did verify that there is an update in the new ware that is supposed to address a "droped cylinder issue" I called and they asked how many times I installed the new firmware, I said 1, They said sometimes ya have to do it like 3 times. So I updated it 4 times last night and reinstalled the map ya gave me.. hoping we get some half decent weather this weekend so I can go test her out...
post #10 of 17 Old 01-15-2013, 07:29 AM Thread Starter
whans1980's Avatar
That had to be scary.......
Power Commander V? 08zx10r15 Performance and Tech 2 05-05-2010 09:06 PM
Power race issue. Can i trust them? Addiction_V Performance and Tech 20 03-07-2009 02:47 AM
power commander for 04/05 garth285 Wanted: Buy or Trade 2 06-09-2008 08:39 PM
Power Commander III zixxer Performance and Tech 9 07-08-2007 12:27 PM
power commander map rroobb The ZX-10R 2 05-05-2007 02:56 PM
