Gen 5: 2016- Non-kit Cut Times - Page 3 - Kawasaki ZX-10R.net
 4Likes
post #21 of 30 Old 05-24-2018, 11:41 AM
Originally Posted by Honey Badger View Post
Yes, we're going to reflash it and make sure the things we can control are all set up properly for what I'll be running this weekend - doing that this afternoon on my way to the track actually. So will test it out tomorrow and see if things improve, or if there's an easier work around (like just making sure I don't wind out 4th gear)....
I remember having shifting issues on my old zx10r where it would pop out of a gear and go back into the previous. After messing about with it, I've realized that the issue was two-fold. First, it was me being lazy and not pushing the lever down deliberately enough. And two, what had amplified my lazy shifting is that I was running a woodcraft gp shift knuckle. The reason for it is its shape, as it has a side-step in it so that you can flip it (for gp shift) and still clear the front sprocket cover (just like your graves one). The issue with that shift knuckle is that it's shorter than the OEM, which means that the shift rod has to travel further to create a positive shift. So basically this increases a chance of an incomplete shift in case you half-ass your push on the lever. So in the end, I tossed the woodcraft knuckle and went back to the OEM one AND re-trained my brain/foot to execute better shifts. Haven't had a problem for a couple of years. I took a quick look at your shift setup at Laguna and noticed that Graves shift knuckle is very similar to Woodcraft in that it has a side step in it but, more importantly, it is also shorter than OEM. Unfortunately, in the case of gen5 zx10r, the side step is necessary because the OEM shift sensor is wide so it has to be offset by the knuckle (and rearset) to clear the frame. So you're kind of stuck with the shorter knuckle, which means that all you can do is try your hardest to be very deliberate with your shifts until it becomes muscle memory. Also, when looking at your shift knuckle and shift rod, make sure they form a 90 degree angle or as close as possible to it. This will ensure that the distance shift rod needs to travel for up and down shifts is the same.
halfswede likes this.
Lanister is offline
post #22 of 30 Old 05-24-2018, 11:46 AM Thread Starter
Honey Badger's Avatar
Originally Posted by Lanister View Post
Honestly part of why I haven't dealt with this issue until now was that I was blaming my leg for most of the problems, not a matter of being lazy persay, but just the simple fact that I can't feel the peg or shifter with that foot anymore, plus the limited ROM.
That part is getting better, I'm re-training the muscle memory to take over rather than relying on feel, so at this point, that's less of a concern (not saying it's eliminated as a factor on occasion, but it's something I've had to be very deliberate about this year with my slightly better functioning leg).
We shall see what I end up with come tomorrow
Lanister likes this.
Racing Like a Honey Badger Blog
AFM #302
Special thanks to my 2017 sponsors and supporters!!
Kawasaki USA Team Green; DareDevil Motorsports; Roseville Yamaha-Kawasaki; RiderzLaw; Dainese D-Store SF; BARF Racing; Dunlop Race Tires; Woodcraft; Pacific Track Time; Motion Pro; Skratch Labs; PUSH Laptimer
Honey Badger is offline
post #23 of 30 Old 05-24-2018, 01:13 PM
I'm using the Graves knuckle (I think), with the Graves rearsets, and the stock sensor. However, I had to lose the countershaft sprocket cover.
Not sure if HB is using the same Graves rearsets, as I've heard there are different versions, but this setup works very well, with no interference issues.
CanyonCarver is offline
post #24 of 30 Old 05-24-2018, 03:30 PM
Why did you have to lose the sprocket cover? Was there a fitment/clearance issue?
Lanister is offline
post #25 of 30 Old 05-24-2018, 03:32 PM
I'm asking because the Graves website shows the rearsets with the cover still on:
Lanister is offline
post #26 of 30 Old 05-24-2018, 04:12 PM
Honestly, it's been a couple years, and I can't recall for sure. I seem to recall that it interfered with the knuckle. Graves may have made changes since I got my rearsets, as they were an early short-run they did for some race teams. They had a few extra sets and posted up on this forum, so I pounced on a set. Point being, they may have made alterations before selling them in larger numbers.
Then again, I did that on my Gen4, and may have just stuck with it 'cause it's easier to clean. Sorry, I wish I had a for-sure answer for you.
post #27 of 30 Old 05-24-2018, 05:16 PM
That makes sense. I reckon they've improved the knuckle design for gen5s. Although in your picture it looks the same. That said, maybe gen4 sprocket cover is different shape and doesn't allow enough clearance.
Lanister is offline
post #28 of 30 Old 06-04-2018, 03:16 PM
Send a message via Skype™ to halfswede
i have also same shifting issue while hard acceleration but stil in lean angle.a
my friend told me i maybe not left the shifting peg coming back totally in resting position, he says my foot is propably left resting on the shifting peg a litle becouse i am stil in a lean angle.
next week going to a trackday again and i will try to lift my foot better between shifting in lean angle.
halfswede is offline
post #29 of 30 Old 06-06-2018, 02:21 PM
Was just at Mugello MotoGP round and was surprised to see a Puccetti WSBK team bike on display in one of the rooms. I took a close look at its shifter knuckle and it's the same size and shape (or damn close) as the Graves one. So I reckon it's good enough :)
CanyonCarver likes this.
Lanister is offline
post #30 of 30 Old 06-06-2018, 02:39 PM
I'm not surprised. These Graves rearsets are the only brand I've used that I like as much as the Attacks. Very solid, with no slop at all. And they crash well. A big thumbs-up, fwiw.
Gen 4: Bazzaz QS cut times ahtune69 The ZX-10R 29 09-21-2014 08:25 PM
Gen 4: Factory Kit Race Parts :Akrapovic. Kit Harness & ECU Bevan175 Parts, Gear and Accessories 0 06-28-2011 01:58 PM
WTB power commander, mps switch kit, and nitrous kit on1wheel01 Wanted: Buy or Trade 3 04-12-2011 11:56 AM
Brand New Muzzy Zx-14 No-cut Frame Slider Kit! Speed Kills! Parts, Gear and Accessories 2 09-23-2007 12:31 AM
