1Likes
  • 1 Post By blink.
post #1 of 10 Old 05-06-2019, 03:18 PM Thread Starter
Need to identify part asap plz
Taking off the air box i found this glued blocked off hole then same on ths throttle body. Including the hose crammed and clogged with shit. Any input any1?
ID:	422247   Click image for larger version
ID:	422249   Click image for larger version
Justin Williams is offline
post #2 of 10 Old 05-06-2019, 03:20 PM
GreenWeenie's Avatar
PAIR valve connection
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is online now
post #3 of 10 Old 05-06-2019, 03:54 PM
michael4012's Avatar
Wink
as above somebody previously blocked the clean air system, cheaply
michael4012 is offline
post #4 of 10 Old 05-06-2019, 06:29 PM
blink.'s Avatar
Looks like gorilla glue to block it off.
michael4012 likes this.
blink. is offline
post #5 of 10 Old 05-13-2019, 07:43 AM Thread Starter
So what would be the point or benefit from doing so?
post #6 of 10 Old 05-13-2019, 10:45 AM
nakedinseattle's Avatar
It's an emissions thing. It pulls air from your airbox, through a pump, and into your exhaust system on top of the engine so that unburned gasses will combust in your exhaust, most commonly heard as the backfiring when closed throttle, slowing down etc.
In relation to tuning, it gives false air fuel readings as it's injecting air into the exhaust side of the system, so blocking it off allows a tuner to properly do their job.
There's numerous ways to remove the system, the right way is with a cap on the airbox nipple and block off plates on the engine block, the lazy way is to just plug the holes with whatever your crafty self can come up with like marbles and screws and clamps or in this case, some gorilla glue.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #7 of 10 Old 05-14-2019, 03:31 AM
or10r's Avatar
Very nice explanation my man. Rep comin your way for that one.
or10r is offline
post #8 of 10 Old 05-14-2019, 10:22 AM
caught me on a good day when i had the time haha thanks
Shut up and ride.
post #9 of 10 Old 05-14-2019, 11:21 PM Thread Starter
Ah ok makes sense which reminds me it seems that I have quite a bit of backfiring on deceleration all depending on how high RPMs are and gear. Ect. Ect. I read it was because of unburned fuel in the exhaust and what not so at first I wasn't sure if I needed to do something to fix it or change the plugs or what to do still haven't done anything about it either. But I am having a major major problem with fuel curious I use the highest octane at the gas stations and I don't just ride full wide open throttle all the time Everywhere I Go but yes filling up on 14 $15 a little bit over a hundred miles my gas light will be back on. And if ran out of gas a couple times! Remove the Power Commander to see if it was going bad and you tell a difference in throttle response and whatnot. But gas is still leaving me SOL
post #10 of 10 Old 05-15-2019, 11:18 AM
the blocked tubes may be leaking air. what is your major major problem with fuel? is the power commander still working? save the map and zero it out then ride it and see the difference. it probably needs to be put on a dyno and tuned.
Shut up and ride.
need asap plz help throttle , front brake master cylinder mrkidd Wanted: Buy or Trade 7 11-06-2012 06:13 PM
Gen 1: Identify this air/fuel system part for me please? Crownan Performance and Tech 2 07-25-2011 03:17 PM
Gen 3: Identify this part ? les301m The ZX-10R 8 06-06-2011 08:19 PM
Help me identify this part. Lucky10R The ZX-10R 28 05-11-2008 02:02 PM
Need 1/5 help ASAP PLZ SUPER K The ZX-10R 9 07-23-2007 09:49 PM
