Gen 1: 2004-2005 leaky drain bolt - Kawasaki ZX-10R.net
 5Likes
post #1 of 18 Old 07-26-2018, 11:53 AM Thread Starter
10roller's Avatar
leaky drain bolt
ive got a small oil leak at my drain bolt. having trouble sourcing a decent oil pan and ive replaced the bolt and still have a leak. Ive use liquid gasket sealer around the bolt in the past with mixed results.
anybody have any ideas for a permanent fix?
10roller is offline
post #2 of 18 Old 07-26-2018, 11:59 AM
ddipaola's Avatar
Did you forget to replace or use a crush washer?
When in doubt... send it!
ddipaola is offline
post #3 of 18 Old 07-26-2018, 01:13 PM
My old 03 636 had that happen when I accidentally overtightened and screwed up the threads.. I was able to use one of those drain bolts that cuts into the threading and was slightly bigger but it only lasted about 2 oil changes before I had to replace the pan
tjg312 is offline
post #4 of 18 Old 07-26-2018, 04:47 PM Thread Starter
10roller's Avatar
New bolt came with new crush washer, still leaks.
10roller is offline
post #5 of 18 Old 07-26-2018, 06:05 PM
Bottoms-Up's Avatar
Threads are ok?
You can torque to spec ok?
Perhaps the pan it self is cracked from over tightening?
If cracked only pan replacement will fix.
If threads are messed up, fix threads with Heli-coil or Time-Sert.
Bottoms-Up is offline
post #6 of 18 Old 07-27-2018, 07:59 AM
ddipaola's Avatar
Yeah there very well could be a crack in the pan from the prev. owner or even from you over-tightening the drain bolt at one point. I would make sure you're torquing to spec first of all and if that doesn't work you could even try putting like Teflon Tape on the threads... that would probably help if the crack (granted you have one) is a hairline.
ddipaola is offline
post #7 of 18 Old 07-27-2018, 08:33 AM Thread Starter
10roller's Avatar
thanks for the ideas fellas. will double check for a crack and start with the easiest options first.
ddipaola likes this.
10roller is offline
post #8 of 18 Old 07-27-2018, 09:22 AM
crack or threads.. sucks when shit happens.
primacarne is offline
post #9 of 18 Old 07-27-2018, 01:41 PM
Porschenut's Avatar
Ditto above. 1. Take off pan. 2. Deliver to a shop. 3. Shop puts a heli-coil in.
2013 ABS, Bridgestone T30 Evo, Woolich, Danmoto shorty & link, Rifleman's 1/5th turn, K&N, GP shift, Gen5 shock/links/dogbone, geared (-1/+0), Shorai, EBC HH, AllBallz roller steering, Ohlins NIX30, Lightech adjusters. Bestem carbon. 50,000km+ and good so far.
Porschenut is offline
post #10 of 18 Old 07-27-2018, 02:11 PM
LDH
LDH's Avatar
Heli-coil doesn't do shit if the pan is cracked...
LDH is offline
Gen 1: Draining coolant via water pump drain bolt ballbag The ZX-10R 9 10-19-2011 09:25 PM
Coolant drain bolt sealing washer. Lougots Performance and Tech 4 05-31-2010 08:03 AM
Advice: Oil drain bolt Stealth Rider Performance and Tech 29 11-25-2009 09:19 AM
Oil Drain Bolt ? RickRoush03 Performance and Tech 14 02-23-2007 05:07 PM
Coolant drain bolt safety wire pics!!! zx10ragentblack Test Area 3 04-29-2006 10:32 PM
