Gen 1: 2004-2005 leaky drain bolt - Page 2 - Kawasaki ZX-10R.net
 5Likes
post #11 of 18 Old 07-27-2018, 02:11 PM
You can also smear RTV high temp silicone around crush washer for better seal at drain hole. If threads are bad you will be able to feel it when applying torque. Heli-coil will fix that as others said. Be sure your straight when you drill! Good luck!
wheelz96 is offline
post #12 of 18 Old 07-27-2018, 02:57 PM
Porschenut's Avatar
Originally Posted by LDH View Post
Heli-coil doesn't do shit if the pan is cracked...
Yes, to clarify, the shop would be a pretty bad one if they went ahead with a heli-coil if the pan is cracked. Moreover, the OP wouldn't bother taking it to a shop after finding a crack in the pan after removal. I'm sure we'd all agree that the most likely cause of the leak is partly stripped threading.
Apologies to the OP for my abbreviated reply but it demonstrates my ignorance since the cracked pans I've seen were from lowered cars bottoming out. I can't recall seeing a cracked pan from over tightening and stripped threads were the result. I worked for a drive through oil change place in Uni so I saw more than a few leaking drain plugs during that time.
2013 ABS, Bridgestone T30 Evo, Woolich, Danmoto shorty & link, Rifleman's 1/5th turn, K&N, GP shift, Gen5 shock/links/dogbone, geared (-1/+0), Shorai, EBC HH, AllBallz roller steering, Ohlins NIX30, Lightech adjusters. Bestem carbon. 50,000km+ and good so far.
Porschenut is offline
post #13 of 18 Old 07-27-2018, 03:09 PM
LDH
LDH's Avatar
For the record I have seen motorcycle oil pans cracked dozens of times from over-tightening the drain bolt. Cast AL pan gives up and cracks at the bolt hole instead of stripping the threads. If you keep turning the bolt and you get a quick thud just as it starts to get tight then goes loose again, it's usually a cracked pan.
wheelz96 likes this.
LDH is offline
post #14 of 18 Old 07-27-2018, 03:57 PM
Porschenut's Avatar
Ahh, very good to know! I wonder if it's because motorcycle engineers are chasing lightweight over durability and the pans are cast thinner? If it's the case it definitely warrants more caution doing oil changes on bikes vs. cars.
post #15 of 18 Old 07-27-2018, 04:13 PM
LDH
LDH's Avatar
It's because everybody thinks they are mechanic even though they wrench like a gorilla.
LDH is offline
post #16 of 18 Old 07-27-2018, 05:41 PM
Otto Man's Avatar
Send a message via AIM to Otto Man
If you have a K&N oil filter, it could very well be seeping oil and running down to the drain bolt and looks like the bolt is the culprit.
Otto Man is offline
post #17 of 18 Old 07-27-2018, 06:10 PM
Bottoms-Up's Avatar
Just install a race spec catch pan and put a little kitty litter in it, that will
hold you over for a while.
ddipaola likes this.
Bottoms-Up is online now
post #18 of 18 Old 07-27-2018, 07:39 PM
blink.'s Avatar
blink. is offline
Gen 1: Draining coolant via water pump drain bolt ballbag The ZX-10R 9 10-19-2011 09:25 PM
Coolant drain bolt sealing washer. Lougots Performance and Tech 4 05-31-2010 08:03 AM
Advice: Oil drain bolt Stealth Rider Performance and Tech 29 11-25-2009 09:19 AM
Oil Drain Bolt ? RickRoush03 Performance and Tech 14 02-23-2007 05:07 PM
Coolant drain bolt safety wire pics!!! zx10ragentblack Test Area 3 04-29-2006 10:32 PM
