Gen 5: 2016- Kit ECU resource thread - Page 5 - Kawasaki ZX-10R.net
 18Likes
post #41 of 47 Old 03-27-2019, 03:57 AM
That is why i asked if you are using a map or are you on default?
Another question is: can you describe as best as you can the weirdness of the idle? Is it when hot? Is it on cold? Always? Misfire?
Then we might find out what is going on. Maybe post a short video with the sound it makes.
morpheusro is offline
post #42 of 47 Old 03-31-2019, 07:58 AM
I had the chance to test out the engine braking and that was the cause of the bike cutting off just from rolling off the throttle. I increased the engine braking map from 1 to 3 and problem solved. The engine braking map 3 felt like the old 1 to me. I didn't have to change the bike setup too much and it didnt feel like I was free rolling into the corner either.
tonyugoh is offline
post #43 of 47 Old 04-01-2019, 09:27 AM
I am using the 2019 kit and the first part of the throttle seems smooth and then I have a bit of a flat spot and then the power comes on strong again. The air fuel is spot on 13.1 in the flat feeling area. Does anyone else have this issue?
bbsteinnewyork is offline
post #44 of 47 Old 04-05-2019, 06:51 PM
Well I just purchased the Ftecu update to the Kit ECU. I think I see why it feels flat in the mid range. I'll test it on Sunday
post #45 of 47 Old 04-05-2019, 07:00 PM
Formerly CLCRACINGAaron
Neonmarine's Avatar
I didnít know they did that?
"You must subsume yourself to the bike"-Casey Stoner
"Thereís a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #46 of 47 Old 04-06-2019, 06:18 PM
Yes they do. It's really nice. All the base mapping is exposed and the KRT settings are separated. It makes it really easy to work with. I wired the ftecu active tune to the Kit wireharness. It made making a base map really fast and in addition I added the Aim MXS 1.2 dash. Ftecu's software pushes additional data channels to the Aim data logger.
Neonmarine likes this.
post #47 of 47 Old 04-06-2019, 06:50 PM
Neonmarine's Avatar
Very cool, Iím not gonna trust myself with making adjustments just yet, so Iíll have my tuner do it at the track until I get used to the bike again. Good to know you can do stuff like that though.
Race kit ECU VS. Flashed ECU gen 5? scotman623 Performance and Tech 23 12-04-2016 07:39 AM
Gen 4: Race kit ECU Settings vs stock ECU abadassbikerlad The ZX-10R 1 03-15-2014 07:27 PM
Wanted: Want to buy: Gen 3 Stock ECU or Kit ECU with Cable Fred-R Wanted: Buy or Trade 3 11-17-2011 06:46 PM
Gen 4: Factory Kit Race Parts :Akrapovic. Kit Harness & ECU Bevan175 Parts, Gear and Accessories 0 06-28-2011 01:58 PM
Need a Kawasaki inside resource!!! HELP!!! kastanbmx01 General Motorcycle Discussions 0 11-11-2009 10:03 PM
