Gen 1: 2004-2005 Ignition Control Module V - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By EvokedPotential
post #1 of 6 Old 11-26-2018, 01:31 PM Thread Starter
I have an 04 zx10r with full Muzzy exhaust, PC5, Ignition Control Module 5, Wide Band 2 Module, Secondary Throttle Plates removed, TRE, exhaust servo removed, velocity stacks, flashed ECU the list goes on...
I took it in and had it mapped on a dyno and after doing so i hooked up my laptop to the power commander to look at the mapping ( Just Curious ) and i noticed that there was no additional mapping to the ignition module, is this something i should have mapped as well and what are the benefits of doing so???
Please excuse me for being clueless on the subject of mapping
Padlock572 is offline
post #2 of 6 Old 11-26-2018, 05:24 PM
EvokedPotential's Avatar
If you look around you'll find that the OEM ignition curve is just about perfect on the Gen1 and no real gains can be had until you start playing with cams. The one benefit of the IM is lifting the rev limited 500rpm which, again, is something you shouldn't do until you have a different cam, shimmed springs, and G3 or titanium retainers.
gaz likes this.
EvokedPotential is offline
post #3 of 6 Old 11-26-2018, 08:12 PM Thread Starter
i had the head done and during this process i had Ti retainers and valves installed as well had the valve seats cut and flowed on a 5 axis cnc machine and had the intake ports polished.
ID:	420381   Click image for larger version
post #4 of 6 Old 11-26-2018, 08:13 PM Thread Starter
and had the cam lobes polished, should i utilize the rev extend feature?
post #5 of 6 Old 11-26-2018, 08:49 PM
gaz
dyno graph holds the answer power still climbing at rev limit or falling off before or at it.
gaz is offline
post #6 of 6 Old 12-22-2018, 07:39 PM
Zedonesled's Avatar
Uhh, who flowed that head and do you recommend them. I'm looking for a Porter and thinking ward. What say you?
Zedonesled is offline
information on TFI fuel injection control module a1cblaine Performance and Tech 0 12-11-2008 08:40 AM
Ignition Module - Tested finally !! Ivan Performance and Tech 70 01-25-2006 11:56 AM
PC111USB, Ignition Module and Speedo Healer coach Performance and Tech 11 12-28-2005 03:13 PM
dynojet ignition module den Performance and Tech 10 08-17-2005 08:39 PM
Dynojet Ignition module EMAIL response jrsjkd The ZX-10R 10 05-20-2005 05:56 PM
