Gen 4: 2011-2015 How critical is a tune or flash for a mostly street bike? - Page 2 - Kawasaki ZX-10R.net
 1Likes
post #11 of 14 Old 06-13-2019, 11:51 AM
nakedinseattle's Avatar
Send it to 2 Wheel DynoWorks. He uses Woolich but is the best out there for mail in flashes, each flash is custom built to the mods on the bike, it's not just a flat canned flash.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #12 of 14 Old 06-13-2019, 11:41 PM
arc
arc's Avatar
I'm on my third gen 4 zx-10r, the first two (circa 112,000 kms across them) had PCVs and this third one, which has done circa 147,000 kms, has had a Woolich flash from close to day one.
All of these bikes are for street use, with occasional track days.
Night and day. Simply night and day. I would never not flash a future bike.
Of the two options, mail in vs self flash I'd always go with self flash. Why? Because you can flash it back at the drop of a hat, you can tweak it as much as you want to perfect your own unique tune. Two bikes coming out of the factory next to each other will require different tuning, that's just the way the world works. No two bikes ever benefit from exactly the same fuelling. Doing that is always a compromise. Useful too if you get an EPA type notice too. And if God forbid something happens to your ECU in the mail then you'll be up for a world of cost with a new immobilizer etc.
So. Go self flash. Is it hard, no. I've written several articles on how to use this, these are stickies on Justin's Woolich Racing Forum and are also hosted on my personal not for profit rider website https://www.arcnineohnine.com (hint, under "articles"), direct links below.
Right, now you've decided to self flash with Woolich, what will you get out of it? As near to a perfect tune as you want. Removal of fuel cut on decel, one of the very worst things ever done to our bikes, no need to add block off plates (which are seriously fiddly and very time consuming to install), no need for a resister pack to allow removal of the exhaust exup valve and perfect fuelling. So what? Perfect fuelling, who cares? To give you an idea my 2nd gen 4 with PCV would get a *maximum* of 200kms to a tank, my current one gets 240-280kms to a tank. What else? Smoothness. A beautiful tune lends itself to a beautifully smooth throttle feel.
Have a look at
https://www.arcnineohnine.com/so-you...ur-bike-tuned/
https://www.arcnineohnine.com/autotune-for-dummies/
https://www.arcnineohnine.com/autotu...kes-good-data/
and
https://www.arcnineohnine.com/autotune-settings/
Happy to answer questions on this as I've been there since Justin released his very first flashing kit for the gen 4 zx-10r over six years ago. I prefer to answer questions in a public forum so that others can benefit.
Arc NineOhNine.
Tomorrow, when I wake, or think I do, what shall I say of today?
Samuel Beckett, Waiting for Godot
arc is offline
post #13 of 14 Old 06-15-2019, 12:08 PM Thread Starter
Fantastic info. Thanks arc! Looks like the Woolich site is the only place to order from?
Graves going on tonight which I understand is fine for awhile pre-tune?
Planning to with -1 front for street and save the +2 for later.
GLJazz is offline
post #14 of 14 Old 06-15-2019, 06:22 PM
arc
arc's Avatar
Anything that allows more air in or less restriction for exhaust gases out dictates a tune. Your bike won't implode but your exhaust valves will run hotter and could be damaged. FTR I like having an AFR display too, I use the hacker/tweaker board, so that I can be 100% confident during tuning that I'm not sitting in dangerous fuelling territory.
A.
arc is offline
