help... electrical issue - Kawasaki ZX-10R.net
post #1 of 6 Old 12-29-2013, 12:13 PM Thread Starter
Last September while going to start the bike I notice the fuel pump was not priming and I was hearing what sounded like the relay junction box (possible I'm not using the correct name there) was shorting out, giving a almost static like noise. It was coming towards the end of season anyway so I put it away. Recently I ordered a new junction box, installed it, started right up took it for a quick ride, everything all good. Today I go out to start it up to let it run a bit and I hear the same sound. Take everything apart. Unplug the wire closest to the rear of the bike, plug it back in, all good. Pump primes. I turn it off, turn the key, again it doesn't work. So I unplug it and I notice there seems to be some condensation around the inside of the plug. I took a hair dryer and dried it out and it worked fine again. Question is is there something I can do to keep moisture/condensation whatever u want to call it from getting inside that plug, do I need to replace that wire harness? Any advice would be awesome. I will get some pics later on today and post them up when I get a chance.
billszx10 is offline
post #2 of 6 Old 12-29-2013, 12:52 PM
tacp_daddy's Avatar
If you don't plan to unplug/plug it often, I'd just say shrink wrap it.
1990 CR 125 - blow'd up
2005 SV1000s - sold
2012 ZX-10R - sold
1987 YZF600 Track-only death machine
tacp_daddy is offline
post #3 of 6 Old 12-29-2013, 07:16 PM Thread Starter
Yeah that's probably the plan but there has to be reason why this is happening. I also found it odd that when I went down to the local shop to order the junction box there was a girl in there getting the same part for the same year (04) 10r. I guess no one else here has had this issue? Seems rare that 2 people in the same area and not a particularly damp area at that (south central pa) would have the same problem same bike as just a fluke.
post #4 of 6 Old 12-29-2013, 07:25 PM
mackFLY's Avatar
Or dielectric grease will help on the seal in the connection
mackFLY is offline
post #5 of 6 Old 12-29-2013, 07:31 PM
chiffeee's Avatar
Yes i would use soft terminal grease or battery grease works too.
chiffeee is offline
post #6 of 6 Old 12-29-2013, 07:44 PM
A pic might help people to give you more accurate advice.
I'm not sure what the junction box you refer to is.
Are you referring to the relay itself?
Are you sure it's water/condensation issue?
Maybe the wrong part? Burning out?
Strange that condensation should be adversely affecting the same part repeatedly.
Dermo is offline
Gen 3: zx10r wont start electrical issue? mrpea Performance and Tech 41 03-06-2016 03:26 PM
Gen 4: Electrical issue? sdiver68 The ZX-10R 13 07-02-2012 06:44 PM
Strange Electrical Issue Jingalls1000 The ZX-10R 5 01-29-2009 05:41 PM
ZX-10R '05 electrical issue Fillbiker Performance and Tech 7 04-17-2007 11:27 AM
Electrical Issue sonic397 Performance and Tech 8 09-16-2006 04:20 AM
