Gen 2: 2006-2007 Having a hard time reinstalling Throttle Body - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By BOP Leader
post #1 of 4 Old 10-07-2018, 07:16 AM Thread Starter
Any tricks to this? I had the engine out of my gen 2 for around 6 months with no throttle body connected and I've spent HOURS trying to get it back on with no luck. I've removed and reinstalled it years ago and remember it being a PITA but not this hard, tried a bit of engine oil around the tops of the rubber boots and tried heating the rubber boots with a hair dryer... Should I buy a heat gun and give that a try?
Do the rubber boots get hard over time and need replacing? the bike has 48k on it
donkey-shlong is offline
post #2 of 4 Old 10-07-2018, 09:35 AM
Make sure all screws for the rubbers are nice and loose, lube and start one side and gradually work your way over. They can be a bitch for sure.
More tips here: https://www.zx-10r.net/forum/f28/thr...on-318834.html
Capncalyx likes this.
BOP Leader is offline
post #3 of 4 Old 10-07-2018, 11:12 AM
F 18 driver's Avatar
Hello donkey-shlong,
I think I may be able to help you. I've had the throttle bodies out at least 10 times in the last 2 weeks… Let me explain the technique I am using
As stated supra lubricate throttle body and the rubber housings…
I start from the back with all the throttle bodies partially inserted into the rubber housings than just push forward and down until you hear a pop … Then I very gently use a rubber mallet to make sure they're fully seated
Be extremely careful and mindful of the sensors when inserting the throttle bodies they can snap off easily with little or no effort…
F 18 driver is offline
post #4 of 4 Old 10-13-2018, 01:44 AM Thread Starter
Thanks for the reply's guys, was helpful but I also needed to use a heatgun... I highly doubt mine could of been put on without one... I added a post in the Gen 2: Throttle body Assy Installation (https://www.zx-10r.net/forum/f28/thr...ml#post4472109) hopefully it can become like a go-to thread for people struggling.
Gen 4: Problems reinstalling clutch casey.r.fitz The ZX-10R 2 08-10-2018 08:03 AM
Need Help! Bike having hard time starting sometimes! ikaika Performance and Tech 3 06-22-2011 02:04 AM
Anyone having a hard time finding specific gear/accessories stateside. highsider General Motorcycle Discussions 2 03-10-2010 03:24 PM
Why am having such a hard time finding green leathers? b4tn General Motorcycle Discussions 12 09-23-2008 10:29 AM
Having a hard time waiting for track days. Otis Race and Stunt 8 02-11-2007 08:09 PM
