Hard Evidence for a Hard Break-in - Kawasaki ZX-10R.net
post #1 of 30 Old 06-24-2004, 05:30 PM Thread Starter
Hey guys, I posted this in another thread about someone's dyno results, and I figured it warranted starting a new thread to discuss. Anyway, I have some info that offers very good evidence for the "hard" break-in. Here's what I posted in the other thread:
I don't want to start a war here, but between Motoman's site and this quote of lycoming's site (they make aircraft engines for the those that don't know) I think that a hard break-in is not only beneficial, but a REQUIREMENT. Now, the quote:
" There are some aircraft owners and pilots who would prefer to use low power settings for cruise during the break-in period. This is not recommended. A good break-in requires that the piston rings expand sufficiently to seat with the cylinder walls during the engine break-in period. This seating of the ring with the cylinder wall will only occur when pressures inside the cylinder are great enough to cause expansion of the piston rings. Pressures in the cylinder only become great enough for a good break-in when power settings above 65% are used.
Full power for takeoff and climb during the break-in period is not harmful; it is beneficial, although engine temperatures should be monitored closely to insure that overheating does not occur. Cruise power settings above 65%, and preferably in the 70% to 75% of rated power range should be used to achieve a good engine break-in."
And here's the clincher from their site:
"For those who still think that running the engine hard during break-in falls into the category of cruel and unusual punishment, there is one more argument for high power settings during engine break-in. The use of low power settings does not expand the piston rings enough, and a film of oil is left on the cylinder walls. The high temperatures in the combustion chamber will oxidize this oil film so that it creates a condition commonly known as glazing of the cylinder walls. When this happens, the ring break-in process stops, and excessive oil consumption frequently occurs. The bad news is that extensive glazing can only be corrected by removing the cylinders and rehoning the walls. This is expensive, and it is an expense that can be avoided by proper break in procedures."
Now, if the people that make some of the most reliable piston engines in the world say to use full power during break-in or else LOSE performance, then, by God, i'm' going to do the same. I'm sure some of you on this forum are familiar with aircraft and the rediculous reliability expected of their engines. Here's the link to the original page for those interested:
http://www.lycoming.textron.com/main...neBreakIn.html
Consequently, the first thing I did on tuesday with my 0 miles ZX-10 after it warmed up was head out to the interstate and run it through the gears, and it just keeps getting stronger with 100 miles on the clock now, no oil burn or anything. I can't wait to get about 1000 or 2000 miles on it and dyno it and see the results! :)
Ok, someone argue with me
Brandon
'04 ZX-10R-The fastest color, black.
BBaxR6 is offline
post #2 of 30 Old 06-24-2004, 05:37 PM
D
To each his own - all I'll say is that Lycoming didn't make the 10 so I think that followin the recommendations from the manufacturer is a good idea.
I'm not a complete idiot...some peices are missing
D is offline
post #3 of 30 Old 06-24-2004, 05:48 PM
wheelup702's Avatar
Send a message via AIM to wheelup702 Send a message via Yahoo to wheelup702
I have always been too impatient to break bikes in properly. I have never had a problem with any of my bikes. I try to stay somewhat close to what the manufacturers say about break ins, but occasionally I veer from the program... I have never had an oil comsumption problems or anything. You can do what you want to do with break in, just don't expect the dealership to give you a new motor if you beat the hell out of it....
wheelup702 is offline
post #4 of 30 Old 06-24-2004, 06:41 PM
Louks03's Avatar
Send a message via AIM to Louks03 Send a message via MSN to Louks03 Send a message via Yahoo to Louks03
I still trust the lil guys that made my machine.
I work on aircraft and we don't have a break in period. Although it could be the fact that you could fly a Cessna into the intake of one my engines. LOL
Not sure if it has to power to weight ratio of my 10R either.
769,000lbs dry (add another 352,000lbs for a full tank of fuel and maybe 10,000 for oil and Hydraulics) 50,000lbs of thrust X 4 engines. Its a little tall fer my taste though. 65' at the tail.
www.doodie.com
Louks03 is offline
post #5 of 30 Old 06-24-2004, 06:48 PM Thread Starter
Obviously if those engines had pistons rings to break in, you'd have bigger problems! :shock: That's a C-5, correct.....GE turbofans?
I don't 8)
Brandon
BBaxR6 is offline
post #6 of 30 Old 06-24-2004, 06:51 PM
Okay!
I have stayed pretty much out of this one but here are some things to consider.
Some Piston rings are made of chromoly steel, Some are made from cast iron, and so on and so on, Some cylinders are made of iron and some are soft steel and so on and so on,
These things make the difference between hard breakin and soft breakin as far as ring seating is concerned, As far as bearings and film oil protection goes, You should never have fisical contact between a bearing and a rod or main journal surface so there would be no breakin required, You do more damage to your bearings during cold startup and oil changes than you would do running your engine hard during breakin!
Now!
There is a possibility to have casting slag floating around in a new engine but it is going to screw you at any rpm.
My opinion on breakin is to very the rpm contantly as well as engine temp so as to season and seat all surfaces, I agree with Lycoming that you don't want to run a new engine at a low power setting for a long period of time as this will cause glazing and I have had to go back into an engine to deglaze after an improper breakin.
I'm sure you all have seen several different procedures from well known performance as well as stock production company's, anybody ever looked at breakin procedures for Comp Cams?
I did this shite for a livin fer many years. 8)
If you are in front of me, It's cause I'm Aiming!!!
Poky is offline
post #7 of 30 Old 06-24-2004, 11:23 PM
OG Post Whore
stunnerific_harry's Avatar
Send a message via AIM to stunnerific_harry
thats a huge b*%ch
stunnerific_harry is offline
post #8 of 30 Old 06-24-2004, 11:33 PM
Louks03's Avatar
I don't 8)
Yap...
www.doodie.com
Louks03 is offline
post #9 of 30 Old 06-24-2004, 11:49 PM
SacCityZ's Avatar
Bet that thing is almost as heavy as the '04 CBR.
2004 Black ZX-10R
Prepare for Ludicrous speed!
SacCityZ is offline
post #10 of 30 Old 06-25-2004, 12:02 AM
44
44's Avatar
first of all, the piston rings do not expand with the pressure in the cylinder. They expand with the heat generated. Secondly there should be always a film of oil in the cylinder wall to prevent scratching of cylinders. thats what oil serves. if the burden is burned oil use full synthetic oil. ıf the guys who make the engine believe that easy break in will damage the engine they would not recommend it. ıf you do hard break in your bike may go well in the beginning however it will not last longer.
did I follow up the break in instructions? unfortunately not because ı can not. :)
WINNERS NEVER QUIT, QUITTERS NEVER WIN
YOU GET WHAT YOU DESERVE
44 is offline
The break in miles gixxerich The ZX-10R 20 05-13-2004 11:48 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
