Gen 5: 2016- GP Shift / Factory Rearsets - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By SkyDork
post #1 of 9 Old 04-12-2019, 07:08 PM Thread Starter
Hi all,
Turns out that after years of using GP shift exclusively, I really don't want to go back to a normal shift pattern. I'd like to switch my 2016 Zx10R, and read some conflicting information so I figured I'd ask. Is it possible to have GP shift using the factory rearsets? And if so, is it possible to use the factory quickshifter in GP shift? I managed to pick up a Woolich LogBox second hand that I just need to buy a bin file for, and have no problem buying the race tools key if that would suffice, in fact I intended on purchasing it eventually anyway. I also have no problem with switching out the shift arm if need be, I'd just prefer not to switch the rearsets. Thanks!
~Mike
Riptide912 is offline
post #2 of 9 Old 04-19-2019, 01:23 PM
meanstreak5's Avatar
I have some after mkt rearset on my 17 with gp shift works great with stock qs. Attack brand
2000 WR400 SM, 2004 KTM 300EXC, 2005 1800 Wing, 2006 ZX10R, 2017 ZX10R
meanstreak5 is offline
post #3 of 9 Old 04-19-2019, 03:36 PM
To the OP, you will need something like the Attack rearsets above that include a reversing pivot or a different mechanism to change direction of the gear-select shaft. It's easy to tell the ECU that you want to reverse the pattern to select cut or auto-blip respectively, but your are still manually changing the gears. I don't think the stock levers allow for that.
2wheelmike is offline
post #4 of 9 Old 04-19-2019, 04:01 PM
SkyDork's Avatar
I haven't logged on in awhile as I've been crazy busy as of late. But since I'm here now and this topic is front and center, I'll give you my solution.
My Gen 5 is using the GP shift pattern, with the factory rearsets, factory QS sensor, and no ECU software changes. The only thing you need to do is use a bellcrank configuration. It's not the cheapest way to go, but it's a bolt-on piece and works great without having to worry about clearances with anything else.
https://www.bikesportdevelopments.co...KT114&CartID=1
WILDWHISKEYWOLF likes this.
#WordCrimes
SkyDork is offline
post #5 of 9 Old 04-19-2019, 10:35 PM
michael4012's Avatar
Hes been on the missing list for months And then BOOM hes back with industry changing replies
michael4012 is online now
post #6 of 9 Old 07-11-2019, 01:40 PM
So I'm taking my bike in for a tune anyway so I was going to have him unlock the autoblip as well. With just the woolich software and def code, can the bike be switched to race shift and still have the autoblip and qs? Or do i need the race tools qs sensor?
Tia!
twistedmistersartz is offline
post #7 of 9 Old 07-12-2019, 05:30 AM
WILDWHISKEYWOLF's Avatar
Can you post some pics with this setup on your bike?
Sent from my iPhone using Tapatalk Pro
WILDWHISKEYWOLF is offline
post #8 of 9 Old 07-16-2019, 01:51 PM
Twistedsocal13's Avatar
Tia!
the woolich software let's you do it with the stock sensors. it has options for gp or standard shift and options to enable auto blip if you don't already have it. If you switch rear sets to attack or vortex and use the gp shift deal on the rear sets you won't need to change the selection on the woolich software to gp shift since the rear set does all the stuff going to the bike the same and it only changes where the lever is concerned
Twistedsocal13 is offline
post #9 of 9 Old 07-16-2019, 02:09 PM
SkyDork's Avatar
Sorry for the late reply. Here's the photos of mine.
ID:	423317   Click image for larger version
#WordCrimes
SkyDork is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
michael4012
Trade: Std shift DJ QS for GP Shift ls1leadfoot Wanted: Buy or Trade 2 02-07-2014 09:56 PM
Gen 1 reverse shift / gp shift rapid van cleef The ZX-10R 5 12-13-2012 11:02 PM
Gen 4: Vortex rearsets(or others) gp shift patern pictures needed. livharder The ZX-10R 8 09-15-2011 09:05 AM
FS: Sato Black GP Shift Rearsets for 03-04 Kawi 636,6rr yehzx10r Parts, Gear and Accessories 0 06-28-2005 09:55 PM
