Gen 1: 2004-2005 Generator repair bulletin - Page 26 - Kawasaki ZX-10R.net
 3Likes
post #251 of 258 Old 08-20-2018, 10:43 AM
sextaafondo's Avatar
I'd say that all units need the upgrade up to the serial number indicated.
Better safe than sorry, it'd worth checking out in what condition are your generator components. It's not an easy job, so if you don't trust your mechanical skills better get this done by a professional. There are precise tolerances to check out and reinstallation of the generator in the engine needs to be taken care of with attention to precision as indicated on the bulletin.
Pablo.-
sextaafondo is offline
post #252 of 258 Old 04-26-2019, 10:56 AM
Hi all! :)
In my 05 I had a little bit buzzing like from the clutch area, intensified at 3k+ rpm. Although it is a 2005 model, I decided to check the generator. Everything looks ok, washer and spacer like in the pictures. Washer from the generator and gear side they are both 1.4mm. But the gap between the washer and spacer is around 1-1.1mm. Is it necessary to adjust the gap in 05 (newest generator) as in the 0.6-0.9mm service?
Thanks for help and sorry for bad english :(
masterowns8 is offline
post #253 of 258 Old 04-26-2019, 10:58 AM
Sorry for spam...
post #254 of 258 Old 04-26-2019, 11:03 AM
GreenWeenie's Avatar
Yep, I lost two motors to the generator wallowing out
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
post #255 of 258 Old 04-26-2019, 11:25 AM
Originally Posted by masterowns8 View Post
Hi all! :)
Your english is perfect. I wouldn't touch the tolerance on your generator. Leave it as is. What you can't reuse are the C clips; you need to install new ones. These can't ever be reused. Be extremely careful assembling everything back together, and mainly the position of the assembly in the engine crankcase. Follow the instructions carefully and to the last word.
Pablo.-
post #256 of 258 Old 04-26-2019, 11:55 AM
thanks, so assebly this on this parts? But what about the buzzing? I paste down below to engine from 3 days ago. What about bought 1 spacer new (because one looks veery good), and change washer from gear side from 1.4 to 1.6/1.8? Then will be gap +- 0.6mm. Now its 1-1.1mm, take a sound of engine, im preety sure that noise like buzzing from washer in engine, maybe its clutch but i dont think so...
post #257 of 258 Old 04-26-2019, 01:27 PM
Thanks, so assebly this on this parts? But what about the buzzing? I paste down below to engine from 3 days ago. What about bought 1 spacer new (because one looks veery good), and change washer from gear side from 1.4 to 1.6/1.8? Then will be gap +- 0.6mm. Now its 1-1.1mm, take a sound of engine, im preety sure that noise like buzzing from washer in engine, maybe its clutch but i dont think so...
post #258 of 258 Old 04-27-2019, 03:36 AM
Gen 1: generator dabl131 Wanted: Buy or Trade 1 03-20-2012 06:03 AM
Will a 2nd gen kit generator fit the 3d gen? Balogiannis Performance and Tech 10 12-19-2010 01:58 AM
WTB 05 Generator RDLYN13000 Wanted: Buy or Trade 11 06-28-2010 07:06 PM
05 generator lenshead Test Area 0 06-21-2009 12:08 PM
Gen 1 Generator bkkninja Wanted: Buy or Trade 6 05-25-2008 08:11 PM
