gen5 swingarm on gen4 - Kawasaki ZX-10R.net
 3Likes
  • 1 Post By Porschenut
  • 2 Post By Lanister
post #1 of 5 Old 02-07-2019, 07:28 AM Thread Starter
mpp12's Avatar
Is there any benefit for the change... ?
mpp12 is offline
post #2 of 5 Old 02-07-2019, 12:25 PM
ypyk_xau's Avatar
It is a bit longer. Nothing major. You will get some wheelbase but does not worth it.
ypyk_xau is offline
post #3 of 5 Old 02-07-2019, 02:44 PM
Porschenut's Avatar
15mm longer if I recall correctly and should resist the wheelies a bit better? I love my wheelies and I'm running the 5th gen links, dogbone and shock with my original 4th gen swingarm. If you want to emulate the 5th gen swingarm you could first start by running a longer chain and running your axle further back in the 4th gen swingarm.
bbsteinnewyork likes this.
2013 ABS, Bridgestone T30 Evo, Woolich, Danmoto shorty & link, Rifleman's 1/5th turn, K&N, GP shift, Gen5 shock/links/dogbone, geared (-1/+0), Shorai, EBC HH, AllBallz roller steering, Ohlins NIX30, Lightech adjusters. Bestem carbon. 50,000km+ and good so far.
Porschenut is offline
post #4 of 5 Old 02-07-2019, 03:45 PM
I was wondering about this as well. I don't remember if the frame changed between Gen4 and Gen5.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #5 of 5 Old 02-07-2019, 04:40 PM
The frame dimensions are effectively exactly the same. I do believe the kick-stand mounting spot is angled differently but that's kind of irrelevant.
As far as putting gen5 swing arm on gen4--I would say it's totally worth it. Yes it's longer, which is a benefit already, but I would also reckon that it has improved rigidity properties for side flex for better grip at lean angle.
Gen4 swingarm was a good try but not ideal, as I remember hearing about pro races drilling holes in them to get more flex. If you compare two bikes side by side, gen5 swing arm has more going on. It is beefier with welds in new spots. I would also combine that with gen5 linkage.
Speaking of which, I will soon have a spare gen5 swing arm with carbon fibre covers pre-installed. For 2019, Motoamerica had outlawed any type of swingarm covers for stock 1000 class so I can't run them. I don't really want to be pulling the cf covers and spend a weekend cleaning off the glue so I'll just get a different swing arm. So I'm happy to sell this one to anyone looking to upgrade their gen4.
ID:	420993   Click image for larger version
realpsi and michael4012 like this.
Lanister is offline
Converting gen4 to gen5 ukzx10r The ZX-10R 35 11-04-2018 08:40 PM
Possible gen4.5? Parts from gen5 renegade1776 The ZX-10R 53 12-05-2016 12:09 PM
I put a Deposit on the Gen4 versus R1 and Gen5 sanfranciscoriderr The ZX-10R 19 05-22-2016 09:47 AM
gen4 vs gen5 mpp12 The ZX-10R 0 03-31-2016 10:21 AM
Gen4 wheels to gen5 ? Ktmjohno Suspension and Tire Tech 11 01-21-2016 05:02 PM
