gen4 front fender on gen5 - Kawasaki ZX-10R.net
post #1 of 8 Old 12-27-2018, 04:21 PM Thread Starter
Hey guys, I was recently told that a Gen4 front fender will fit on a Gen5. Is that true? From what I know, the gen5 forks are 10mm further apart than gen4 as far as wheel spacing goes--but that obviously doesn't speak for the mounting points for the fender. Has anyone ever tried this? I am trying to see if I can run a gen4 fender on my gen5--because I prefer it more.
Lanister is offline
post #2 of 8 Old 12-27-2018, 05:21 PM
97grnrs's Avatar
I know the hayabusa fender fits both, I have one on my Gen 4 and I've seen them on 5,could prob easily modify to make anything fit. I have 2 Gen 4 fenders if needed
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. https://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #3 of 8 Old 12-28-2018, 11:07 AM
It'll fit. Ran my whole Gen4 bodywork, less the tailsection, for a couple years.
CanyonCarver is offline
post #4 of 8 Old 12-28-2018, 12:29 PM
ShawnG's Avatar
Gen 5 front fender is trash
ShawnG is offline
post #5 of 8 Old 12-28-2018, 01:47 PM Thread Starter
Did you have to stretch the fender outward a little bit?
Lanister is offline
post #6 of 8 Old 12-28-2018, 11:07 PM
I have both and was going to run this swap as well. I can report back once my forks get back from service
John297 is offline
post #7 of 8 Old 12-29-2018, 07:41 AM
Not that I can recall. Seemed to fit fine to me.
post #8 of 8 Old 12-30-2018, 09:15 AM
Carlos76's Avatar
When i fitted gen5 fender (race bodywork) the story was:
Yes, fender is a bit wider (gen5 forks more apart). Fender did bend enough to fit. But then I replaced front wheel and when taking out axle the fender pulls forks apart (turning lower fork legs). This makes installing axle very uncomfortable. Ended putting spacers between fender and fork, problem solved.
Edit: Sorry this is vice versa, but same applies, I think you will need to bend fender out when installing axle.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
Gen 5: FT: Gen5 White Front Fender for Black Lanister Parts, Gear and Accessories 1 02-23-2018 02:05 PM
Wanted: Gen4 Saddleman seat, ALL green lowers (both), green front fender and green front cowl KIXASS Parts, Gear and Accessories 0 05-03-2017 01:00 AM
Gen 5: NRC Fender Eliminator Kit and Front Flush Turn Signals for Gen5's are released! MotoMillion The ZX-10R 20 03-11-2017 01:35 AM
Possible gen4.5? Parts from gen5 renegade1776 The ZX-10R 53 12-05-2016 12:09 PM
Gen4 wheels to gen5 ? Ktmjohno Suspension and Tire Tech 11 01-21-2016 05:02 PM
