Gen2 water pump issue - Page 3 - Kawasaki ZX-10R.net
 1Likes
post #21 of 24 Old 07-19-2015, 08:40 AM Thread Starter
Any coolant will do for cars at 50/50 mix..
Took my old pump apart today and it looked super clean with no slop in shaft at all(10,000 miles from new),there seems to be a o-ring inside the body which I assume stops oil getting to water impeller.then there's the big o-ring on the body which stops oil getting to atmosphere. Then there's the ceramic mechanical seal stoping water getting out to weep hole..
The two o-rings are easy once removed as you can just buy new ones same dimensions,but the ceramic seal is not available. What I did notice is the the white ceramic disk can be flipped 180 to reveal a new surface! (Might work)??
But looking at earlier Kawasaki seals I must say they look identical to the 06 ZX10R.!?? Might buy one a see for my self..plus 06 Suzuki TL1000 seals look identical too!
Update soon ish lol..
krakers10r is offline
post #22 of 24 Old 07-20-2015, 12:03 PM
Starbucks Connoisseur
Static IP's Avatar
Well I ordered the pump and had it replaced and used Maxima Coolanol
and now my bike gets up to 174'ish an and not flashing "hi" after 5 minutes of idling.
Found a site that sold it WAY below what others are selling it for, its normally $223 everywhere and I got it for $177 otd
09' Ice Blended Peppermint Mocha Frappuccino
10' Venti Mocha Latte spilled some of it, was too hot
11' Peppermint Mocha W/Extra Shot of Espresso
12' Eggnog Venti Latte
13' Bagel
14' Standard Drip (since a Venti latte went up 20 cents)
Static IP is offline
post #23 of 24 Old 08-03-2015, 07:08 AM
I am probably going to be needing a water pump for my 07 soon. Does anybody know a good site to order a water pump from that is cheaper than $223?
Thanks,
Brad
07spec_ed is offline
post #24 of 24 Old 09-06-2015, 02:47 AM
I ended up getting the water pump from 2wheelpros. It was under $200. I ordered that and all of my clutch components and it was at my door in about a week.
Part Number 49044-0005
Gen 1: Water Pump 1killer1liter Wanted: Buy or Trade 8 10-21-2014 11:25 PM
Wanted: Gen2/3 Water Pump - Faulty foursix Wanted: Buy or Trade 0 09-03-2014 10:34 AM
2004 ZX10R Water Pump/Oil Pump leak notjeep The ZX-10R 4 09-17-2013 10:07 PM
Gen 2: Is the Gen2 water pump the same as Gen3? antaren The ZX-10R 0 06-04-2013 01:57 PM
Gen 2: Water pump help? KyleJones General Motorcycle Discussions 2 10-15-2012 07:33 AM
