Gen2 water pump issue - Page 2 - Kawasaki ZX-10R.net
 1Likes
post #11 of 24 Old 04-24-2015, 02:09 PM
O ring
Check the oring seal if it's broke when you put the pump out from the crankcase.
ninja_12r2000 is offline
post #12 of 24 Old 04-24-2015, 02:43 PM
OxyG3nE's Avatar
got to get a new pump! on 3 engine the 3 failed and no parts to fix it :p
OxyG3nE is offline
post #13 of 24 Old 05-02-2015, 05:53 PM Thread Starter
No gen2 pumps in UK and none in Holland so has to come direct from Japan (20+ days)!
From Cradley UK....
krakers10r is offline
post #14 of 24 Old 05-02-2015, 06:26 PM
Water pump failure
Check water pump from gen 1, 2 and 3, almost same part number 2005 part / 49044-0003, 2006 part/ 49044-0005, 2008 part/ 49044-0008,
Now on ebay when you look at water pump pics from 2004 through 2010 it's looking the same, good idea is to check with a salvage yard if the water pump from 2004 through 2010 are interchangeable, From 2011 I know they change the pump configuration.
So maybe you can save a lot of money that way.
post #15 of 24 Old 05-03-2015, 02:26 AM Thread Starter
04-5= 189
06-7= 196
08-9= 197
I'd only buy new anyway (do it once do it right ect) so I may as well get specific year pump.
Ordered it a week ago anyway but cheers fella!
post #16 of 24 Old 05-23-2015, 06:06 PM Thread Starter
Finally got the new pump from Japan on Thursday and fitted today,all went well and no leaks..
O-ring fully intact and looks like a new pump to be honest so don't really no why it was leaking coolant(must be an inner mechanical seal!).
Now I'm thinking of stripping it down to check shaft for any defects and if ok surely I must be able to source a new aftermarket seal that will go in??? Be nice to fix it for a spare! What you guys you think??
post #17 of 24 Old 05-23-2015, 10:22 PM
Sasquatch's Avatar
If you can find replacement seals, I'd certainly be interested. My old water pump was mechanically fine as far as I could tell. Seals would be a cheap and easy way to get back on the road.
Have a wheelie nice day!
Winter sucks.
Sasquatch is offline
post #18 of 24 Old 05-24-2015, 05:45 AM Thread Starter
I will try but I'm surprised nobody has ever done this for the gen1-2 as buying a new water pump everytime is exspensive!
Anyway I will see what we can do....
Cheers
Sasquatch likes this.
post #19 of 24 Old 05-24-2015, 09:35 AM
I just replaced the water pump as well with an Ebay one. I haven't had a chance to try it out but when I pulled mine it still looked good. It would be a great thing if someone could find just replacement seals. I did my research and looked around, couldn't find much.
Zew2888 is offline
post #20 of 24 Old 07-01-2015, 01:06 AM
Starbucks Connoisseur
Static IP's Avatar
Glad I found this post. Ran into the same issue when I took my bike in for an oil change. The shop told me you're leaking coolant (from the minor amount of coolant buildup) and also my bike gets super hot fast and flashes "HI" after 15-20 min of riding around town.
Is it safe to assume that it's the seal on the water pump that went bad?
Since I also did my research and would have to get a WHOLE new pump for a seal that went bad. I don't have a leak of coolant on the floor when the bike is parked. This issue has been going on for a few months, so I held off on the oil change (planning on getting all done at the same time if I have to install a new WP)..
Also what coolant would you guys recommend?
It's a 2006 ZX-10R
And in Southern Cali.
Thanks!
09' Ice Blended Peppermint Mocha Frappuccino
10' Venti Mocha Latte spilled some of it, was too hot
11' Peppermint Mocha W/Extra Shot of Espresso
12' Eggnog Venti Latte
13' Bagel
14' Standard Drip (since a Venti latte went up 20 cents)
Static IP is offline
Gen 1: Water Pump 1killer1liter Wanted: Buy or Trade 8 10-21-2014 11:25 PM
Wanted: Gen2/3 Water Pump - Faulty foursix Wanted: Buy or Trade 0 09-03-2014 10:34 AM
2004 ZX10R Water Pump/Oil Pump leak notjeep The ZX-10R 4 09-17-2013 10:07 PM
Gen 2: Is the Gen2 water pump the same as Gen3? antaren The ZX-10R 0 06-04-2013 01:57 PM
Gen 2: Water pump help? KyleJones General Motorcycle Discussions 2 10-15-2012 07:33 AM
