Gen 4: removing counterbalancing shaft - Kawasaki ZX-10R.net
 2Likes
post #1 of 13 Old 01-22-2019, 05:36 AM Thread Starter
ypyk_xau's Avatar
Hey guys, need some input on removing the counterbalancing shaft. Someone tried it? According to the manual, there is no need to split the motor just removing the oil pan and you can pull off the counterbalancer, correct?
ypyk_xau is offline
post #2 of 13 Old 01-22-2019, 07:11 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
Looks pretty simple. Any known adverse affects? I've done this on a car motors and didn't realize you could do this on a bike. I'd love to know if this was a simple mod that doesn't have any severe adverse effects!
"You must subsume yourself to the bike"-Casey Stoner
"Thereís a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #3 of 13 Old 01-22-2019, 07:14 AM
mpp12's Avatar
why would you want to do that???
mpp12 is offline
post #4 of 13 Old 01-22-2019, 07:22 AM
Neonmarine's Avatar
Reduce the rotating mass. APE makes a dummy balance shaft for the Gen4 that simply installs in place of the factory unit. Retails for $30.
post #5 of 13 Old 01-22-2019, 10:37 AM Thread Starter
ypyk_xau's Avatar
faster revving, cons are you are getting additional vibrations from the motor. I would like to put this https://store.schnitzracing.com/ape-...i-zx10r-11-15/
ypyk_xau is offline
post #6 of 13 Old 01-22-2019, 10:38 AM Thread Starter
ypyk_xau's Avatar
Pros are faster rev motor. Cons are additional vibrations. I am not sure how this feels and looking for someone for expirience. Archer did that but is not in the forum anymore...
ypyk_xau is offline
post #7 of 13 Old 01-22-2019, 10:46 AM Thread Starter
ypyk_xau's Avatar
I am willing to do it in case no splitting cases is required. If just the oil pan needs to go, ok, I am in but if not, no bueno. If you can hande some vibrations then you are ok I guess. Need an input from someone that rode this
ypyk_xau is offline
post #8 of 13 Old 01-22-2019, 11:00 AM
My GSXR-1000R doesn't have one. You will notice it missing!
gaz likes this.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #9 of 13 Old 01-22-2019, 12:08 PM
michael4012's Avatar
Iv build a G4 motor removing the balance shaft & fitted the APE shaft, but i also had the crank lightened balanced and edged at the same time, now i never rode that bike but the owner said he could feel a difference in vibration but it wasn't prohibitive in long road rides generally he was very pleased with the way the motor spins up faster on road and track. But that was with a balanced crank, and as the motor was built as a package i couldn't tell you what real power gains there were (if any)
michael4012 is offline
post #10 of 13 Old 03-26-2019, 06:58 AM
C3L1CA's Avatar
I put the APE dummy shaft in my bike a few days ago while the motor was out. It was as simple as undoing those 2 bolts and pulling it out. I did have a bit of a hard time getting the shaft out, ended up grabbing it with a pair of vice grips and hit the vice grips with a hammer as I figured I'm not putting it back in anyways lol
Cheapest 1.5lbs of weight savings I think I've done to the bike
michael4012 likes this.
C3L1CA is offline
Gen 1: Gen 1 Zx10 transmission shaft get tight when you tighten clutch hub nut Zetnam Performance and Tech 4 10-29-2018 12:28 PM
GEN 3: WTB Mirrors, Shifter Shaft, Solo cowl EVO Wanted: Buy or Trade 3 03-11-2014 07:03 AM
Gen 3: Removing Secondary Throttle Shaft - FI Fix? BGoodwin22 Performance and Tech 15 12-04-2012 07:13 PM
Finished removing the secondary flies shaft and Servo. pic. heavy TENN10 Performance and Tech 19 10-13-2011 04:58 AM
Changing counter shaft sprocket realestateguy The ZX-10R 6 10-24-2004 12:47 PM
