Gen 4 airbox swap from gen 5 - Page 9 - Kawasaki ZX-10R.net
 44Likes
post #81 of 131 Old 01-18-2019, 12:31 PM Thread Starter
ypyk_xau's Avatar
Originally Posted by C3L1CA View Post
That aluminum foil seems like it'd do the trick as that stuff always seems way too damn sticky whenever I've used it. When I heard wrap I was thinking vinyl for some reason and maybe it's just me but that shit always seems to peel up for me and when you're doing 150+ I don't want any peeling in my airbox
Yea that MWR is cool but between that and the other MWR part you need, it seems like a lot of money. I do have a MWR WSBK filter thats been sitting in my garage all last year but just haven't had the time to try and get a tune dialed in for it as I'm afraid to do harm to my motor as they told me I needed to add more fueling to 2 cylinders over the stock tune.
Wonder if these airbox mods will change airflow enough to change the tune per cylinder as well?
You have MWR WSBK in the garage just sitting? Come ooon It requires re-tune though. I checked with EJR just out of curiosity. I will get a Draggy myself and will do comparison soon. So it may lean the tune a bit in high speeds and adding fuel back will result in power. I think this mod is best for roll on racing which I do more. I will check AFR when I get to drive the bike since it is damn cold
ypyk_xau is offline
post #82 of 131 Old 01-18-2019, 12:38 PM
mpp12's Avatar
a normal filter vs the WSBK filter is 3-4% more fuel in the hi rpms... but nothing to worry if your 13.0 already...
mpp12 is offline
post #83 of 131 Old 01-18-2019, 05:17 PM
ddipaola's Avatar
The provided FTECU auto-tune table recommended 13 in the higher RPMs but I thought that was a little rich. I was going to highlight the whole table and +3% it... what do you think?
This table isn't set in stone... was just hypothetically messing around before I apply it (don't even have the actual unit yet).
When in doubt... send it!
ddipaola is offline
post #84 of 131 Old 01-18-2019, 05:26 PM
Formerly CLCRACINGAaron
Neonmarine's Avatar
I think you should get a tune. Iíve never seen a tuned fuel map look that clean. Most bikes have weird lean/rich areas randomly through the tables.
"You must subsume yourself to the bike"-Casey Stoner
"Thereís a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #85 of 131 Old 01-18-2019, 06:00 PM
I wouldn't run 13.36 for roll on racing. I wouldn't do 13.36 on a road course either. Heck I wouldn't do it period unless it proved quicker for 1/4 mile. I mean it is not crazy afr lean, but why dump the heat in the cylinder through 4,5,6 in the high rpms. As the speeds go up time in the higher gear increases. Heat in the cylinder increases for what probably amounts to no appreciable gain between 12.8 to 13.0.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #86 of 131 Old 01-19-2019, 01:04 AM Thread Starter
ypyk_xau's Avatar
This is how it came up. Far from perfect but I am ok with that. It will do the job.
ID:	420771   Click image for larger version
ID:	420773   Click image for larger version
ddipaola likes this.
ypyk_xau is offline
post #87 of 131 Old 01-19-2019, 05:05 AM
Looks good
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #88 of 131 Old 01-19-2019, 06:12 AM Thread Starter
ypyk_xau's Avatar
You need some sort of measuring unit, like dyno or draggy or vbox to see what the bike likes. There is no unified AFR. Tuners and autotune products work for 13.0 by default because this is somewhat considered as best safe power. When I bought my Bazzaz Autotune it came pre set to 13.0 all accross the board. Later when I flashed with Woolich autotune my tuner set 13.4 low and mid and 13.0 high. And you will not be able to tell a difference between 13.0 and 12.5 since it is small difference but a measuring equipment will show which is better.
ypyk_xau is offline
post #89 of 131 Old 01-19-2019, 11:24 PM
ddipaola's Avatar
I'll have to pull up my old dyno sheets, the bikes changed a bit since then but it should provide a good baseline.
ddipaola is offline
post #90 of 131 Old 01-19-2019, 11:25 PM
ddipaola's Avatar
That looks CLEAN. Way better looking than anticipated. Good posting guy
ddipaola is offline
Gen 2 airbox on Gen 1? Hybrid The ZX-10R 0 03-29-2014 05:11 PM
Gen 1 airbox part. 880turbo Wanted: Buy or Trade 2 04-19-2011 08:25 PM
Another swingarm swap question... 1st gen to 2nd gen swap RITCHYRITCH The ZX-10R 2 10-21-2009 03:05 PM
QB Carbon Airbox for 1st Gen? jdgun_13 Performance and Tech 9 09-18-2008 04:23 AM
should I swap to a 06-07 race tail along with my front end swap? garth285 The ZX-10R 10 12-05-2007 09:21 PM
