Gen 4 airbox swap from gen 5 - Page 11 - Kawasaki ZX-10R.net
 44Likes
post #101 of 131 Old 01-29-2019, 12:05 PM
mpp12's Avatar
anyone can tell he what gauge the ECU harness is, Im waiting for my mate, but in case I have to extend the harness.
michael4012 likes this.
mpp12 is offline
post #102 of 131 Old 01-29-2019, 12:14 PM Thread Starter
ypyk_xau's Avatar
I see logic behind it. Also, wsbk bikes Rea and Sykes used MWR xxl intake. What benefit exactly is hard to tell. Every bike woud react diffeently. I can tell for my bike, it is fairly modded so hope for the best.
ypyk_xau is offline
post #103 of 131 Old 01-30-2019, 08:30 AM
ddipaola's Avatar
Those supplier maps (showing power gains) are pretty subjective. The reason I say that is because they're likely showing you a Completely stock bike vs a Completely stock + intake bike. More air on a stock bike would add power, yes. If you look at Sprint's air filter data for the F1 they claim the same thing; 2-3HP gains (don't quote me) solely from bolting it on. Now that IS dyno proven with those parameters BUT I haven't seen how much power is to be gained from putting an F1 on a previously tuned bike. So, I don't think the supplier is BS-ing anyone with those numbers, but I think you're only going to see that 2-3HP on an already modded bike unless you very tediously dyno/street tune it.
That dyno is likely some bone stock de-restricted or Euro spec bike.
When in doubt... send it!
ddipaola is offline
post #104 of 131 Old 01-30-2019, 08:38 AM
ddipaola's Avatar
Originally Posted by bun1t View Post
3-5 hp without mapping. Reminds me of the Motomaxx velocity stacks claims that turned out to produce 0 hp
That I can agree with tenfold. They're claiming, what, and additional 2HP or so ON top of the 200HP their bike was already making on the dyno That's bananas.
SBU runs the motomaxx stacks on their bike but tbh I think they've tuned their bike around all the pros and cons of short stacks. I think they could have left the stacks alone completely and they're bike would still make the same power across the range after all the time they've spent fine tuning... Not to mention the price on those stacks is outrageous.
ddipaola is offline
post #105 of 131 Old 01-30-2019, 11:08 AM
mpp12's Avatar
I dont follow your reasoning....
he showed a normal bike making 183 then 186hp...
mpp12 is offline
post #106 of 131 Old 01-30-2019, 11:23 AM
ddipaola's Avatar
It's a before/after run. They're stating +3HP with the enlarged intake. I'm saying they're probably showing a (euro spec) bone stock bike vs bone stock with their expensive intake to exaggerate their results.
Neonmarine likes this.
ddipaola is offline
post #107 of 131 Old 01-30-2019, 12:53 PM
mpp12's Avatar
being stock wont make the result exaggerate...
mpp12 is offline
post #108 of 131 Old 01-30-2019, 02:16 PM
ddipaola's Avatar
Yes it will. And that's what they're advertising. I guarantee you if they put the same intake on a full bolt on bike they would gain little to nothing. When the bike is completely stock, with more potential to see gains, it's easy to exaggerate your product. Call it exaggeration, exploitation, misleading customers... idc what you want to call it... I call it BS.
ddipaola is offline
post #109 of 131 Old 01-30-2019, 02:20 PM
mpp12's Avatar
if you change 1 variable and it makes a change then it works....
what is a full bolt on bike for you?
have you done dyno work, changing parts? I have and usualy thats how its done, you change only one thing.
motomaxx vel stacks where tested that way showing no results, I also tested like 4 other stacks I made myself showing CERO improvement...(lots of plastic welding).
realpsi likes this.
mpp12 is offline
post #110 of 131 Old 01-30-2019, 02:54 PM
ddipaola's Avatar
No! It doesn't! If you took 5 misc parts that made +1HP improvement over stock you're NOT going to make +5HP when they're all installed at once that final number is going to vary, and that's what I'm trying to point out when saying that prev. graph is exaggerated/misleading.
I don't even know where Motomaxx got their numbers from either. 2HP on top of a 201.4HP Gen5 just because of some short stacks is a bold claim lol. Not surprised they make zero improvements if not make the bike worse lol.
ddipaola is offline
Gen 2 airbox on Gen 1? Hybrid The ZX-10R 0 03-29-2014 05:11 PM
Gen 1 airbox part. 880turbo Wanted: Buy or Trade 2 04-19-2011 08:25 PM
Another swingarm swap question... 1st gen to 2nd gen swap RITCHYRITCH The ZX-10R 2 10-21-2009 03:05 PM
QB Carbon Airbox for 1st Gen? jdgun_13 Performance and Tech 9 09-18-2008 04:23 AM
should I swap to a 06-07 race tail along with my front end swap? garth285 The ZX-10R 10 12-05-2007 09:21 PM
