Gen 4: 2011-2015 Gearing Change - Complicated questions - Page 8 - Kawasaki ZX-10R.net
post #71 of 79 Old 01-16-2014, 06:08 PM
SDsting's Avatar
Images: 22
Thank you cooter, just taking a look at that website now, what is it supposed to do for you? does it calculate similar figures that I listed in my previous post?
SDsting is offline
post #72 of 79 Old 01-16-2014, 11:33 PM
cooter's Avatar
Yep. It will show you stock gearing settings and you can put in your current and custom setting even different tire sizes and rev limits. The website will break down the speeds at different rpms and compare them. It has a lot of stuff that's over my head.
cooter is offline
post #73 of 79 Old 01-17-2014, 07:41 AM
Rideit's Avatar
I'm in the process of going -1 +2........Holy Phuck!! The front sprocket was unbelievable and I was prepared for the legendary reputation for being tight. Laughed at my impact wrench (air) and my 3 ft breaker bar. Ended grabbing an 8ft long piece of oil field trash and grabbed it at about the 6ft mark to bust it loose.......are you kidding me. By the way, I'm 5'10", 195 lbs and no stranger to the gym.
BTW....the retaining washer (only 3,300 miles, Gen4) left all the interior teeth in the splines of the shaft and no dealer within 250 miles of me had one in stock. Now my shits all torn up for a week or so. I guess the point is, if your going to do this, order one ahead of time.
Rideit is offline
post #74 of 79 Old 01-17-2014, 08:23 AM
Kung Fu Panda's Avatar
You flattend that washer out before you tried to get the nut off right? Maybe you didn't get it flat enough and the nut was hitting it.
Kung Fu Panda is offline
post #75 of 79 Old 01-17-2014, 08:46 AM
Rideit's Avatar
Yea, good question though under the circumstances. I flattened it before I started and even went back to it a few times and made sure I REALLY flattened it good due to the difficulty I was having. No chance that washer was binding, probably not even before the first time I tried with the impact
Rideit is offline
post #76 of 79 Old 01-22-2014, 09:59 PM Thread Starter
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
Yeah...in the end...a good combination of Throttle cam adjustment and gearing change will give you what you need....
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS | 2011 ZX10R | 2011 R6 | 2019 KTM 250XC-F
GunnRunnaz.com|Gunn Runnaz on FaceBook
Vonstallin is offline
post #77 of 79 Old 01-09-2019, 05:35 AM
attycuz's Avatar
Sorry just getting myself confused. Can i use the stock chain on -1 front and stock rear? Thanks
attycuz is offline
post #78 of 79 Old 01-09-2019, 08:01 AM
ddipaola's Avatar
Yes. That's what I'm running.
When in doubt... send it!
ddipaola is offline
post #79 of 79 Old 06-26-2019, 06:51 PM
I have done +3 on the rear with OZ Racing wheels. The power on the bike feels very uncomfortable . For example going up in the gears. From 1st 2nd is hard as fuk. Bike jolts when hanging gear.
MR.ZX10R is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
two questions (gearing) feo_mack01 The ZX-10R 24 07-04-2008 11:57 PM
Does gearing change affect dyno #'s 10timestheheat Performance and Tech 21 06-27-2008 12:20 AM
Gearing change rodgers10r Performance and Tech 16 11-09-2007 12:13 PM
Gearing change...worth it? rojapar Performance and Tech 52 02-28-2007 01:06 AM
backwards gearing change Lil Sal Performance and Tech 4 01-16-2007 08:06 PM
