Gear indicator or at least 6th gear indicator? - Kawasaki ZX-10R.net
post #1 of 22 Old 06-14-2012, 02:18 AM Thread Starter
RememberTheMallamo's Avatar
I had a GiPro w/ATRE but ended up selling it because I didn't want the TRE. However, I'd still like to have a gear indicator of some sort. In my opinion the only gears that really matter are 1st, neutral and 6th lol. 1st and neutral are obviously easy but honestly if I could have a dash light similar to the neutral green light that indicated being in 6th gear I'd be set! I hate trying to shift into 7th.
Does anything like this exist? Is it possible to make one? Has anyone had any experience with the cheap magnetic ones on eBay? I've read a little on them but no first hand opinions, especially not with the 10. Any other suggestions also welcome, thanks.
RC51. No more Kwaks :(
RememberTheMallamo is offline
post #2 of 22 Old 06-14-2012, 02:59 AM
bluedevil's Avatar
Did you miss my Sticky in the Performance Section? :
https://www.zx-10r.net/forum/showthread.php?t=41297
You can turn the TRE off and just have a Gear indicator no MESSING please read.
PS....I made my own Gear Indicator have a manual switch to run TRE or NOt....I am not sure the last time I activated it meaning I don't need or miss it.
bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #3 of 22 Old 06-14-2012, 03:21 AM Thread Starter
Yeah but for the money I decided to sell it instead of letting so much functionality go to waste. If I have no other options I could go that route though, thanks.
post #4 of 22 Old 06-14-2012, 03:27 AM
Gen2 Ripper
neverendingmods's Avatar
A gear indicator costs $140 so the ATRE plus indicator is actually a bargain.
Accumen and Healtech electronics both make a gear indicator. I have the healTech, has ZERO lag and works/reads gear while clutch is pulled in or out. Not HUGE like the ATRE indicator either.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #5 of 22 Old 06-14-2012, 03:31 AM
bluedevil's Avatar
There's really not much function in a GiPro....you get a Gear indicator choose to fool the ECU what gear your in ALL THE TIME OR CHOOSE NOT TO FOOL AND GO and go normal mode.....not a bad price for a Gear Indicator I use to charge the same price for mine when I made them.
bloo
post #6 of 22 Old 06-14-2012, 08:35 AM Thread Starter
Ohhhh you made them? Well is my idea for a 6th gear light similar to the neutral light at all possible?
Neverendingmods, I thought Healtech made the GiPro w/ATRE
post #7 of 22 Old 06-14-2012, 09:07 AM
Squid wannabe
rafa's Avatar
accumen in the UK makes a good one. you have to buy the little harness and the indicator, but it is plug and play.
"The ZX-10R is capable of being perfectly docile and tractable, but few men are capable of resisting its ever-present voice urging them to just twist it and see what happens."
rafa is offline
post #8 of 22 Old 06-14-2012, 06:25 PM
Gen2 Ripper
HealTech also makes just a gear indicator that simply plugs into the diagnostic port harness next to ecu. Sees what the ecu sees regarding gear position. Go on their sire and select gear indicators, it will show it.
07-ZX10R-SOLD
05-ZRX1200R-sold
04-KX500-sold
post #9 of 22 Old 06-14-2012, 09:31 PM
bluedevil's Avatar
Yeah I use to make them and it's possible to do what you want RTM the info. is out there on the net....... RTM you will have to search around though to get that info. I haven't been active in this for awhile or interested in revisiting this at this time....sorry
Rafa....here is your Accumen against my Home Made Gear Indicator in it's first phase before production I think you will see it's a little slow.
http://s180.photobucket.com/albums/x34/zx-10r_album/?action=view¤t=gearindicator.mp4
bloo
post #10 of 22 Old 06-14-2012, 09:39 PM
MUSHU's Avatar
That looks good bloo. I'm sure if you can make it members here would hit you up on it.
MUSHU is offline
Gear Indicator jstyled The ZX-10R 9 03-24-2012 09:46 PM
gear indicator rapid van cleef The ZX-10R 2 12-04-2010 05:34 AM
Gear Indicator drock41 General Motorcycle Discussions 26 10-29-2008 03:48 PM
gear indicator for 05 ZX-10 SoCal90 Vendors deals 1 07-09-2008 11:16 AM
Gi Pro Gear Indicator Help?? mattfr12 Performance and Tech 18 04-04-2007 04:45 AM
