"""gear indicator gauge....Who got Em """ - Page 2 - Kawasaki ZX-10R.net
post #11 of 18 Old 03-21-2005, 07:52 PM
crispin's Avatar
Send a message via AIM to crispin
I think the board is falling apart today.
Anyone got any revalent post today?
VON - Why do you think you need the gear indacators for?
You do not need to be studing your gauges either on or off the track.
Pay attention to the road / track - listen to the bike
Screaming = shift up
Not Screaming = Shift down
Fuck what the # of the gear is?
Come on your susposed to be a hard core fucker.
What are you going to need next? Air pressure monitors? Navigation? DVD Player?
Ride the bitch - she is like the weed - she be speaking to you man.
ya ya ya...
crispin is offline
post #12 of 18 Old 03-21-2005, 09:08 PM Thread Starter
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
on the small track i couldnt figure out what gear i was in since 3, 4, and 5 felt the same on lower rpms, but if i was to hi in the gears it didnt have the pull, the larger track was no problem since i work up to 4 gears...the small track 1 to 2 gears...
just want to know, to tell the truth i never did look down, but if i knew i had a gear indicator i would have.
I might be a bad ass in the street, but the track is a different world...im like a newborn baby there :(
CCS/ASRA Novice 325 | WERA Novice 325 | The Nightmare of Summit Point
2016 ZX10R ABS | 2011 ZX10R | 2019 KTM 250XC-F
GunnRunnaz.com|Gunn Runnaz on FaceBook
Vonstallin is offline
post #13 of 18 Old 03-21-2005, 09:23 PM
crispin's Avatar
My Point tho is you shouldn't be looking at your gagues while on the track.
I think you might be being too 'technical' for your own good.
If you are concentrating too much on the perfect gear, perfect braking spot, perfect apex you won't develop the 'flow' needed to be fast.
Von - hit the track, relax, do not follow other riders - you will get your grove and be a bad ass racer. Worry too much and you wont be much.
Thats just my 2 cents.
ya ya ya...
crispin is offline
post #14 of 18 Old 03-21-2005, 10:00 PM
bluedevil's Avatar
I have the Acumen gear indicator and trust me you won't use it on the track. It's just not fast enough and you will be concentrating on alot of other things. I use mine mostly for street and on the hwy to see exactly when I down shift to play with accellaration senarios in certain gears on the hwy and then go back to top gear when cruising because and because the gear ratio's are so close you forget sometimes that you sitting in fifth gear instead of 6th and thats why I won't part with it. It has it's uses, just not the track.
bluedevil is offline
post #15 of 18 Old 03-22-2005, 12:08 AM
mad kaw's Avatar
I have an Acumen on the 10R and a Digi on the Gix. The Acumen is a lot more reliable. Back it the day when streetbikes had big midrange and widespaced gears it was a no brainer to tell what gear you were in, or when you were in the wrong one. with close ratio boxes and high reving motors they help a lot, particularly when learning a new track. After you get the track wired, it gets more instinctive.
mad kaw is offline
post #16 of 18 Old 03-22-2005, 01:35 AM
R1GSXRKILLER's Avatar
Come on man give the guy a break..it's not like he's racing for a title out there it's for fun remember...dude get your gear indicater if thats what your little ole heart desires.
R1GSXRKILLER is offline
post #17 of 18 Old 03-22-2005, 08:05 AM
MAVRIK's Avatar
Hkmp7 Also Has Them, I Will Be Getting One For 110 And It Is A Plug -n- Play
Everyday is a holiday, every meal is a feast
MAVRIK is offline
post #18 of 18 Old 03-22-2005, 09:48 PM Thread Starter
Vonstallin's Avatar
Images: 16
just havent heard form Hkmp7 lately....
well i just spent $500 on 3 tires from www.ronayers.com so i might leave this item on my wish list instead of my to do list..
i did want 2 of them ....
2 for $199 and then its a done deal...maybe if i hook up with you we can get 3 for $299
what do you think???
run that by him...these are the plug in models right??
