Gear indicator - Kawasaki ZX-10R.net
post #1 of 16 Old 05-27-2004, 11:52 AM Thread Starter
MIA Post Whore
miykl's Avatar
Gear indicator
By far the mod I've made so far!! Check it out here: http://www.bohnarmor.com/riderstations/datatool.html Installation took 15 minutes. Removed wind screen, then the it plugs in in-line with the speedo much like a power commander does. some velcro and zipties to clean up the install, 5 minute on a stand to "program" the gears and you're done. Gear changes took less than a second to be "recognized". Only draw back is you do have to have the gear ingaged (clutch out) for it to indicate the correct gear. Multiple downshifts at a light will make it confused until you take off again then three seconds later, all's good. It's great to glance down and know what gear you are in when in traffic or when making those high end runs, it'll keep you from trying to shift into 7th (ya know you've done it!). I'll get myself sorted with a picture host this evening. Looks cool too ('cause bling does matter some too!)
miykl is offline
post #2 of 16 Old 05-27-2004, 12:25 PM
JLove's Avatar
Thanks for posting this. I have been holding out for them to make a plug-in version for the ZX. I am always trying to shift into 7th. All the time. I am going to order it.
2004 ZX-10R black (sold)
2008 CBR1000RR
2011 ZX-10R ABS Black
#51 NESBA, TPM, Absolute
JLove is offline
post #3 of 16 Old 05-27-2004, 01:15 PM Thread Starter
MIA Post Whore
miykl's Avatar
Installation is a no brainer. I did use electrical tape to give some degree of weather protection at the connectors, otherwise everthing you need is there. I may fab a bracket to eleminate the velcro that is keeking it in place now (supplied with the kit). I also ordered the anodized blue alum housing. Bling, I know, but dresses it up some and matches my "faster blue" 10 well.
miykl is offline
post #4 of 16 Old 05-27-2004, 08:48 PM
mad kaw's Avatar
WTF? You are describing the Acumen and posted a link to the Digi. This is wildly misleading. Digi is NOT in the same league as Acumen. Sheeeeeeesh.
mad kaw is offline
post #5 of 16 Old 05-27-2004, 10:45 PM
Snake Eye's Avatar
What are the colors to be used on the ZX10R?
I have the indicator but dont know wich wires to wich (colors)on the bike???
Please help
2004 zx10r (sold)
2006 zx10r (sold)
2008 zx10r - trackbike
2009 zx10r - streetbike
www.FastFoodRacing.com
Snake Eye is offline
post #6 of 16 Old 05-27-2004, 11:16 PM
mad kaw's Avatar
They are listed on the Acumen website.
mad kaw is offline
post #7 of 16 Old 05-28-2004, 01:08 AM
Send a message via AIM to RUNNINHORN Send a message via Yahoo to RUNNINHORN
so which is better, acumen or Digi?
I was looking at the tach/speedo display tonite, its round, do they make an indicator that is rounded off to butt up perfect to it? or not?
RUNNINHORN is offline
post #8 of 16 Old 05-28-2004, 02:34 AM
mad kaw's Avatar
Acumen. No contest.
mad kaw is offline
post #9 of 16 Old 05-28-2004, 07:06 AM Thread Starter
MIA Post Whore
miykl's Avatar
Sorry for the confusion. It is the Acumen. What can I say? ...Brain overload... ..caught up in a moment.. ahhhhhh.. I suck? The gear indicator rocks though!
miykl is offline
post #10 of 16 Old 05-28-2004, 07:15 AM
I don't get why these guys aren't making a complete, no programming necessary, plug & play gear indicator for the Kwak. It should be easy, as the 10R has a gear position sensor built-in from the factory. Can't see why that signal couldn't be intercepted to feed a display that wouldn't need to be programmed. And it wouldn't be confused by multiple downshifts at a light, and wouldn't need for the clutch to be released to indicate the proper gear. Just wondering. :?
CanyonCarver is online now
Gear shift indicator cashes41 The ZX-10R 12 07-12-2005 07:48 PM
Gear Indicator? JLove The ZX-10R 7 04-27-2004 12:55 PM
Droping out of gear greg570 The ZX-10R 4 04-13-2004 05:02 PM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
