Gen 3: 2008-2010 Gear indicator - Kawasaki ZX-10R.net
post #1 of 7 Old 09-22-2018, 07:10 PM Thread Starter
Gear indicator
I know it's an old topic and I have read many posts about it, but I couldn't find a solution.
I just bought 2009 zx10r, and it seems to lack the gear indicator totally. Even though all the video's I checked earlier has one beside the speed. Is it on some versions ? Or something to activate
2000irl is offline
post #2 of 7 Old 09-24-2018, 09:35 AM
SkyDork's Avatar
Welcome to the party!
The Gen 3 has a gear indicator. It says "GEAR" to the right of the speed. It shows nothing in neutral. So either the cluster is bad, the gear sensor is bad, or you're trying to look at it in neutral.
#WordCrimes
SkyDork is offline
post #3 of 7 Old 09-24-2018, 10:06 AM
michael4012's Avatar
The left hand side of the cluster has a green (n) light which should be on when in neutral as sky said if it's in gear then it would display what gear your in, if it's not indicating a gear number when it is in gear and there is no F1 code it could be that you have Gen1 clocks on it courtesy of the previous owner. It's unlikely but possible.
michael4012 is offline
post #4 of 7 Old 09-24-2018, 10:32 AM
SkyDork's Avatar
All true! Except that the neutral switch to activate the green light is a separate input to the cluster. The input comes into the cluster differently than the gear selection. So just because one works and the other doesn't is not a direct indication. The FI code sort of is the same thing. If the switch hasn't failed, no FI code is generated, but that doesn't mean the switch is working. The FI code mean the switch has failed completely, not that is may or may not be indicating correctly. If the switch is powered on and not sensing what gear is selected, no FI light and no gear indication. Just gotta troubleshoot some more to figure out what the real issue is.
#WordCrimes
SkyDork is offline
post #5 of 7 Old 09-24-2018, 04:21 PM
I get your thinking Skydork, as ever your methodical and express excellent English 😁 I'm thinking that if the gear switch - indicator is broken on the drum itself or in between that and ecu the bike will be running like shit, as the ecu doesn't know what gear it's in, 2000iri hasn't said what it runs like admittedly.
post #6 of 7 Old 09-24-2018, 05:10 PM
SkyDork's Avatar
Would the bike be running poorly in that case? Wouldn't it just be running like it was in neutral all the time? Would that make it run bad, or just different than it should? I remember back when that model came out, the plug-in TRE modules were all the rage. The thought on those was if you kept the ECU thinking it was in one gear all the time, then it would bypass restrictions and make it faster. Or so the story goes.
Yeah, we'll wait to see if the OP responds and we'll diagnose it from that point based on more information.
#WordCrimes
SkyDork is offline
post #7 of 7 Old 09-25-2018, 04:55 AM
GreenOne's Avatar
If the gps signal fails, the ecu sets it to 6th gear. The bike will still run fine.
I`m just in for the ride
GreenOne is offline
Gear indicator or at least 6th gear indicator? RememberTheMallamo The ZX-10R 21 06-16-2012 08:49 PM
Gear shift indicator cashes41 The ZX-10R 12 07-12-2005 07:48 PM
Blue DG8 Digital Gear Indicator BIGRED12R Parts, Gear and Accessories 7 07-15-2004 06:54 PM
Gear indicator miykl The ZX-10R 15 05-28-2004 08:34 PM
Gear Indicator? JLove The ZX-10R 7 04-27-2004 12:55 PM
