Fork Seals: Help with Removing Fork Cap ('05 ZX-10R) - Kawasaki ZX-10R.net
post #1 of 4 Old 08-16-2009, 09:14 PM Thread Starter
I need some advice on how to remove the fork cap from the inner fork assembly. This is for an '05 ZX-10R.
I've followed directions from Garthman (http://www.garthmanracing.com/forkseal.htm) and the instructions from Traxxion Dynamics. I'm using the Traxxion Dynamics spring compressor tool to try to get the job done. Unfortunately, I cannot compress the spring down far enough to place the holding tool; the outer tube assembly is too tall. I've check with the Kawasaki manual, and they suggest using a spring compressor. I do not have access to a spring compressor for motorcycle forks, only one for automotive use.
Does anyone have any experience with this problem? Am I doing something incorrect?
Henry is offline
post #2 of 4 Old 08-16-2009, 10:01 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
When I did the fork seals on my 05, I tried the same as you following Garthmans
how to. What I ended up doing was Remove the Banjo bolt from the bottom
and take it apart. ( Remember or take a pic of which way the seal is installed
before you remove it to have a reference for when you install the new one.)
You really don't want to put them in upside down. So make absolutely sure.
When installing the fork tubes back into the triple tree, install front wheel but
leave it a little loose to be able to adjust your forks.
Read this thread for making sure your forks are straight...
https://zx-10r.net/forum/showthread.php?t=78039
Definitely make sure you torque everything properly or it will cause problems.
Hope this helps ya bro.
hellsrazor is offline
post #3 of 4 Old 08-16-2009, 10:13 PM Thread Starter
I was thinking of removing the Allen bolt from the bottom. I read of someone using an impact Allen head to remove it but I don't know of a place that sells an impact Allen head. That may be my second to last resort.
Henry is offline
post #4 of 4 Old 08-16-2009, 10:40 PM
hellsrazor's Avatar
Images: 23
Yeah, that's the banjo bolt.
Fork Seals??? vamafia46 Performance and Tech 3 07-27-2009 10:08 AM
Fork seals!!! William Hell Performance and Tech 7 07-13-2008 05:21 PM
Fork Seals silversv1k Performance and Tech 43 04-04-2008 05:36 AM
fork seals !!!!! slowblack00 Performance and Tech 5 03-14-2008 04:28 PM
Fork seals are Over it! DustinR The ZX-10R 19 04-19-2005 11:01 AM
