Fork Seals & Dust Cover Recommendations – Gen2 - Kawasaki ZX-10R.net
 3Likes
  • 1 Post By evallarta1
  • 1 Post By LDH
post #1 of 10 Old 10-23-2018, 09:53 PM Thread Starter
F 18 driver's Avatar
Hello everyone,
I have thoroughly read through all the forum posts concerning oil seals and dust seals… But this left me, with no definitive answers, and it's been quite a few years since this question has been posed
I have to replace both front fork seals that have blown out
Is there consensus on the form as to which seals are the best replacements on stock gen2 forks.
1) ALLBALLS - Fork Seal & Dust Seal Kit – they claim to have better seals
2)RACETECH fork seals and dust caps.
3) K & N fork seals and dust caps.
4) OEM fork seals and dust caps
3) Lastly, is there some other brand that I'm not aware of that I should be considering?
Maybe a few of you who have some real-world experience can illuminate the subject and help me and others make the decision as to which brand we should select
Further, in your response. If possible could you elaborate as to which fork oil you would recommend and why
Thanks in advance for your help.
Yours truly,
F-18 driver
F 18 driver is offline
post #2 of 10 Old 10-23-2018, 11:30 PM
Bottoms-Up's Avatar
Manual calls for Kawasaki KHL-15-10 oil
Match something close on the attached chart to the
KHL-15-10
I use Motul Very Light 2.5w
Bottoms-Up is offline
post #3 of 10 Old 10-24-2018, 10:43 AM
97grnrs's Avatar
I've used all balls on numerous bikes without issues, automatic trans fluid can also be used in place of fork oil without issues.
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. https://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #4 of 10 Old 10-24-2018, 05:44 PM
evallarta1's Avatar
We only sell SKF and OEM at our shop. Everything else doesnt hold up or has too much stiction. In fact we refuse to install All Balls.
K-Tech and Race Tech are rebadged OEM seals.
For OEM forks/cartridges we use Maxima Racing Fluid (5wt in your case). Their racing fluid is really good for the price.
LDH likes this.
Velocity Calibrations
evallarta1 is offline
post #5 of 10 Old 10-24-2018, 05:47 PM
evallarta1's Avatar
In older damping fork technology, yes ATF was acceptable. Now a days with cartridges and other advancements in suspension, ATF is usually frowned upon.
post #6 of 10 Old 10-24-2018, 06:29 PM
97grnrs's Avatar
I've never had an issue using atf in even modern street bikes, also never had an issue with the all balls products, my gen 1 is going on a few years on a set with no issues. Can use what you want but I find most product defects are usually caused by installation errors.
97grnrs is offline
post #7 of 10 Old 10-25-2018, 08:15 AM
mattinrsm's Avatar
I'll second the SKF recommendation. The best I've used.
mattinrsm is offline
post #8 of 10 Old 10-28-2018, 07:22 PM
blink.'s Avatar
I've used all balls in numerous bikes with no issues.
blink. is offline
post #9 of 10 Old 10-29-2018, 08:25 PM
evallarta1's Avatar
Feel a brand new all balls kit next to an OEM/SKF set and you'll understand. The ALL Balls feel cheap and like plastic, and have so much stiction in them you almost need to revalve the darn forks.
LDH likes this.
post #10 of 10 Old 10-29-2018, 09:08 PM
LDH
LDH's Avatar
SKF is definitely the way to do it correctly. Funny enough my wife's 1000RR got a new set today along with a fresh service for the Ohlins 25MM carts after I realized that the left fork was leaking
ID:	420167   Click image for larger version
ID:	420169   Click image for larger version
evallarta1 likes this.
LDH is offline
Gen2 unever fork height after seals USCG_zx10r Suspension and Tire Tech 13 07-27-2016 03:44 PM
04-05 Front Wheel Dust Seals - Free caboose Parts, Gear and Accessories 7 04-30-2012 07:10 PM
Gen2 fork seals sam_b03 Wanted: Buy or Trade 5 02-20-2012 08:36 AM
Fork Seals: Help with Removing Fork Cap ('05 ZX-10R) Henry The ZX-10R 3 08-16-2009 10:40 PM
Changing fork oil & seals CheeseHeadNinja Performance and Tech 7 04-30-2009 06:11 PM
