Exhaust systems - Kawasaki ZX-10R.net
post #1 of 29 Old 01-31-2010, 01:48 PM Thread Starter
Exhaust systems
Ok Im new to this forum thing. So here we go. I have a 08 zx10r and I put on a M4 slip on exhaust (Had shop do it). When putting this exhaust on did they remove the CAT. I have read that the CAT is built into the end of the headers. So the only why to get rid of CAT is to cut out or change the headers. Is this true?
spider021 is offline
post #2 of 29 Old 01-31-2010, 01:53 PM
All show and all go 10r
JLG0987's Avatar
1 why the he'll did you have a shop do it? It takes like 30-45 minutes. 2nd no it doesn't get rid of the cat in the header. You'd have to get a aftermarket header or cut open the stocker. Also I don't believe the m4 slip gets rid of the pre box. You'd have to get a link pipe. Also you should get a pc or bazzaz to remap the fuel because you are definitely down on power.
JLG0987 is offline
post #3 of 29 Old 01-31-2010, 02:14 PM
ronnulph's Avatar
Send a message via Yahoo to ronnulph
Yep the Cats are in the two pipes right before the final Y-pipe. I hope the install was free because that was a definitely an easy DIY project.
08 ZX10
ronnulph is offline
post #4 of 29 Old 01-31-2010, 10:28 PM
Aris08's Avatar
Images: 12
I'm getting the Full system because it replaces the entire header back system, the slip on is the part on back of tail, adds lot of power, but last little bit is in the removal of cat. Tuning from something like powercommander is really only going be alot and worth expense if your going to be using it for daily use etc. IE you should do couple mods, like free up air intake, and exhaust before you really go hunting for more in ECU box...
The attitude of my bike is worth the weight
Aris08 is offline
post #5 of 29 Old 01-31-2010, 11:12 PM Thread Starter
i would love to do a full system with the Power Comander. But I live in the North east and NH and MA are passing all these laws. NH is pass a noise law and MA is putting a emmison law in effect soon. So Im going to keep stock headers and just deal with the nice sound of my M4 slip on.
post #6 of 29 Old 02-01-2010, 01:04 AM
I have Acrapovic slipon with linkpipe do i have to mount PC3 or can i have it org?
Mike
minge is offline
post #7 of 29 Old 02-01-2010, 02:09 AM Thread Starter
You do not need a pc3. You should be able to run any slipon. You will loose no power. You will probably get a little more power with the pc3. I run a M4 slipon exhaust without any problems.
post #8 of 29 Old 02-01-2010, 08:53 AM
I got an Akropovic link pipe and put it on myself. It's pretty easy.
Blackjack is offline
post #9 of 29 Old 02-01-2010, 09:20 AM
lyodbraun's Avatar
YES the M4 does get rid of the boom box.... I had one on my bike before I got the LOR.... also there is no need to cut open the stock pipes all you need is a long drill bit to reach inside the pipes and drill out the CATs......
lyodbraun is offline
post #10 of 29 Old 02-15-2010, 05:36 PM
Aris08's Avatar
Images: 12
Technically if you keep the old stock pipes for emissions testing the feds will never know, and sound is only going to go over the limit of about 6k, you can not be tagged over legal limit which is usually 102db, some states as high as 105db... However exp popo's will look for your cats and can still be caught over a casual stop. If you ride like a maniac just go with a slip on...
Aris08 is offline
Gpr Exhaust Systems? hesaves0211 The ZX-10R 9 04-23-2007 06:44 PM
Exhaust systems for 06 ZX-10r? shawnada1 Performance and Tech 17 10-02-2006 08:22 AM
Michigan and aftermarket exhaust systems GoFaster The ZX-10R 12 02-03-2006 09:35 PM
Exhaust systems???? prophet The ZX-10R 27 05-20-2005 02:49 PM
exhaust systems! crazyman1 The ZX-10R 12 05-22-2004 12:01 AM
