Gen 5: 2016- Exhaust Header Gaskets - Kawasaki ZX-10R.net
 4Likes
  • 3 Post By Boxtradamus
  • 1 Post By michael4012
post #1 of 5 Old 02-15-2019, 03:31 PM Thread Starter
ddipaola's Avatar
My Graves headers just came in but they didn't include new gaskets I guess...
I called my local Kawi dealer and they don't stock them...
Is there anywhere local where I can get some non-oem gaskets that will fit Gen5 headers?
When in doubt... send it!
ddipaola is offline
post #2 of 5 Old 02-15-2019, 04:12 PM
Pop out the old ones, flip em around and re use them.
CanyonCarver, LDH and michael4012 like this.
Boxtradamus is offline
post #3 of 5 Old 02-15-2019, 07:26 PM
michael4012's Avatar
Also using a dremel type tool shave away any protruding areas of the gaskets which effect flow. You can check this before you line up the headers simply by holding each gasket onto the sleeve in turn.
TheRoadWarrior likes this.
michael4012 is online now
post #4 of 5 Old 02-19-2019, 01:23 PM
brimal_rage's Avatar
They prob dont stock many of them due to most people dont even change them out. I bought some for my Gen 4 a few years back and ended up not using them so they just sit in my garage. Only time I have replaced them was on my 20+ year old zx-6 with 40k miles on it, no idea if they were ever replaced before either.
Of the multiple exhausts I have replaced on motorcycles I dont recall ever seeing new gaskets included with the exhaust, you should be fine re-using your current ones without issue.
2011 ZX-10R Ebony
brimal_rage is offline
post #5 of 5 Old 02-20-2019, 09:03 AM Thread Starter
ddipaola's Avatar
The stock oem ones had some pretty odd imperfections (that I didn't want to grind/sand down) so I just ended up buying 2 sets of new OEM gaskets. Thankfully they were in stock and will be delivered today.
ddipaola is offline
Gen 3: Header gaskets harobikes167 Parts, Gear and Accessories 2 03-27-2014 11:07 PM
Gen 3: Header gaskets IggyBcool Vendors deals 1 05-01-2012 09:30 AM
** FS- 04-05 BRAND NEW Header gaskets Big Poppah Parts, Gear and Accessories 0 04-02-2007 11:08 PM
Do I need to replace header gaskets KlevaOne Performance and Tech 31 08-18-2006 10:42 AM
removing header exhaust gaskets 41ants Performance and Tech 29 02-22-2006 05:09 PM
