Gen 4: 2011-2015 Electrical issue? - Kawasaki ZX-10R.net
post #1 of 14 Old 06-23-2012, 10:42 PM Thread Starter
sdiver68's Avatar
Electrical issue?
OK here's the symptoms I noticed while riding home tonight after a long day of riding:
1) Headlight varied in intensity. It would be brighter then dimmer, switching every so often between the 2.
2) ABS light started blinking which according to the manual means low voltage. I stopped, shut it down, restarted and light stayed off the remaining 40 miles home
Any thoughts besides take it to the dealer?
TIA!
sdiver68 is offline
post #2 of 14 Old 06-24-2012, 05:53 AM
GSP
GSP's Avatar
Sounds like voltage regulator going bad if not gone.
GSP is offline
post #3 of 14 Old 06-24-2012, 06:04 AM
All show and all go 10r
JLG0987's Avatar
stator might be gone.
JLG0987 is offline
post #4 of 14 Old 06-24-2012, 10:54 AM
The Pace
scout's Avatar
Gotta be some loose connection.
Only funny thing I notice is that the battery always sounds a little weak on startup. Always starts but I'm still not used to it and will ask a tech guy what he thinks. Sure he's heard a few of the g4's start.
In your case, better ask the tech to sort it out. Probably will call up Kaw and they'll tell him exactly, as they have already had a couple like yours.
better mention that mine does not have abs.
scout is offline
post #5 of 14 Old 06-24-2012, 11:00 AM
Gone Ridin'
twidget's Avatar
Send a message via AIM to twidget Send a message via MSN to twidget Send a message via Yahoo to twidget
Either could be the case (although the regulator is probably more likely, I have had a stator failure in the past).
Come to think of it a really bad battery (one with some cell reversal) might cause similar symptoms.
: Twidget
twidget is offline
post #6 of 14 Old 06-24-2012, 09:00 PM
Velociraptor's Avatar
Check your battery first. Mine was bad since the firste day and changed it at the dealer ...
Velociraptor is offline
post #7 of 14 Old 07-02-2012, 09:05 AM Thread Starter
sdiver68's Avatar
New symptoms, FI light turned on twice with FI code, both times within a mile after a warm start. Both times I shut it down rolling, restarted, light went away and stayed off for remainder of ride.
Off to the dealer I go before I get stranded somewhere!
sdiver68 is offline
post #8 of 14 Old 07-02-2012, 10:17 AM
What code did you have?
post #9 of 14 Old 07-02-2012, 10:24 AM
nakedinseattle's Avatar
i'm guessing he didnt check that on his rolling restarts lol. i'm interested in the issue as well, wondering if dealership will say its a normal fault or something specific just to the bike
nakedinseattle is offline
post #10 of 14 Old 07-02-2012, 10:31 AM
I am hoping Kawasaki had solve the stator / rectifier issue that affected previous gens... My 2007 burned two stators and rectifiers and I am scared to hear tha a gen 4 had this issue.. Please nooooo !
Gen 3: zx10r wont start electrical issue? mrpea Performance and Tech 41 03-06-2016 03:26 PM
Electrical? brazen The ZX-10R 10 06-07-2010 03:42 PM
Strange Electrical Issue Jingalls1000 The ZX-10R 5 01-29-2009 05:41 PM
ZX-10R '05 electrical issue Fillbiker Performance and Tech 7 04-17-2007 11:27 AM
Electrical Issue sonic397 Performance and Tech 8 09-16-2006 04:20 AM
