Gen 4: 2011-2015 Dynotronics and Guhl ECU dyno test. Back-to-back. - Kawasaki ZX-10R.net
post #1 of 15 Old 10-26-2011, 12:24 AM Thread Starter
Knaks's Avatar
Took my bike to Orient Express today. But before I went there I took apart my buddies 2011 ZX10 and pulled his Guhl flashed ECU and put in my backpack.
Short and simple, both ECUs made the same identical #'s maybe on a few different runs one might of put out 1HP then the other. The HP and torque curves were pretty much the same. Identical.
Both hit 6th gear limiter at 14,000.
Both ECU's run a little lean up top. We installed the PCV and fixed that on my Dynotronics flash.
So, whoever makes the claim that their flash will give you more HP or smoother power is full of shit. The dyno shows different. Both ECU's back-to-back on the same day on the same dyno showed no difference between the two.
Hit the search button on either company and make your own choice.
Good luck.
Knaks is offline
post #2 of 15 Old 10-26-2011, 12:29 AM
teedub21's Avatar
what exhaust are you running? I wonder if they can richen up the top end a little bit with the flash?
teedub21 is offline
post #3 of 15 Old 10-26-2011, 01:23 AM
tasos's Avatar
Thanks for doing the comparison
tasos is offline
post #4 of 15 Old 10-26-2011, 01:24 AM
rbass1's Avatar
Rep sent
Thanks for taking time and money to do the comparo Knaks!
rbass1 is offline
post #5 of 15 Old 10-26-2011, 02:39 AM
timhanley156's Avatar
I'm glad you settled this whole thing, man. Good to hear.
timhanley156 is offline
post #6 of 15 Old 10-26-2011, 09:30 AM
bmacknyc1000's Avatar
nice results and thanks for spending the money on this information.... and we know Guhl Motors charges less that's who I went with.... and I am very happy with their service....
I've heard Dynotronics is good as well....
Don Guhl uses his own software (he is an amazing programmer and electrical engineer), Dynotronics and the other companies use Passani Engineering software, both will yield the same result... both very good
Guhl can also tune a fuel and ignition map via the ECU now.....
bmacknyc1000 is offline
post #7 of 15 Old 10-26-2011, 11:47 AM
10 ninja r's Avatar
and remove the the f-1 light so you can remove the servo motor.
10 ninja r is offline
post #8 of 15 Old 10-26-2011, 12:59 PM
my own worst enemy
wesley's Avatar
If any of you talk to Joe, can you ask him if there is any progress on getting a replacement ECU for me? I can't get ahold of him.
Also, could Urban Legend please tell us if he had any issues with Dynotronics again?
wesley is offline
post #9 of 15 Old 10-26-2011, 01:08 PM
RDLYN13000's Avatar
Images: 38
Good luck.
ECU testing - YouTube
Guess it all boils down to customer service now?
RDLYN13000 is offline
post #10 of 15 Old 10-26-2011, 01:13 PM
nice review
satttheman is offline
2011zx10r v bmw s1000rr back to back dyno pete 10r The ZX-10R 31 02-10-2011 06:40 PM
rode & raced graves 09 R1 back to back against my 08zx10 desertchecker General Motorcycle Discussions 79 01-13-2010 04:25 AM
just got back the dyno im pleased dunkchamp55 The ZX-10R 3 07-09-2009 02:23 AM
Back From the Dyno ClutchNShift Performance and Tech 11 08-14-2007 12:31 PM
Back from the dyno BNninja The ZX-10R 22 04-18-2005 12:19 PM
