Gen 5: 2016- Doubts about catalyst removal and remapping - Kawasaki ZX-10R.net
 3Likes
post #1 of 19 Old 11-04-2019, 07:03 AM Thread Starter
Hi all,
First of all, I want to apologize*for my bad english.*
I'm looking into a shorty slip-on for my ZX10R 2018 SE, really like the two bros one, here's a link:*https://www.twobros.com/products/kaw...05-4290407-s1b
As you can see, It'd remove the catalyst, so as far as I know this would require to remap fuel injection. Is this true?*
In case a remap is needed:
  • How far is this needed? In case remap it's not done, there would be performance loss regarding OEM exhaust + catalyst?
  • How is it done in this bike? I need a Power Commander kind of tool? OEM ECU can not be remapped?
  • Will I lose some bike features? (i.e Power mode option)
Note: I'm not into hp gain. I only want to change slip-on for sound and esthetic.
Thank you
age000 is offline
post #2 of 19 Old 11-04-2019, 10:35 AM
TheRoadWarrior's Avatar
can add 3/4 exhaust (header back, no catalyst) without ECU remap or power commander... bike will backfire more (sounds awesome to me, but some people dont like it) and some low/off throttle response becomes a little jerky / touchy, but otherwise its totally fine.
Guarf likes this.
TheRoadWarrior is offline
post #3 of 19 Old 11-04-2019, 03:25 PM
I have a danmoto catdelete and an akrapovic slipon installed. The result is quite back fire when decelerating (if you are driving fast and at high rpm, if you are driving normal in the city you rarely hear anything).
Ecu flashed with Woolich to remove the restrictions of ETV maps and the result is excellent. You do not lose any functionality of the bike, but you have the possibility to modify any configuration.
What is your native language?
Guarf is offline
post #4 of 19 Old 11-05-2019, 07:24 AM Thread Starter
I'm from Barcelona, so spanish and catalan.
I love back fire noises, that's not a problem.
My concerns are about a performance downgrade. I remember back in 2011, when I purchased a 2bros full line to my Ninja 250R, I didn't install a power commander in a first instance. Bike had real troubles to pass 9-10K rev range on high gears and that kind of problems are what I'm trying to avoid right now.
Time to stretch bike performance will come when I feel I could go faster. Right now I'm not using even a 75% of this beast.
age000 is offline
post #5 of 19 Old 11-05-2019, 11:11 AM
GreenWeenie's Avatar
Be careful, if you remove the cat, make sure the link pipe has a bung to allow for the o2 sensors. Remap allows for removal of the o2 sensors.
If you dont remap, I highly suggest an Autotune unit.
GreenWeenie is offline
post #6 of 19 Old 11-05-2019, 11:51 AM
ive been riding with 3/4 system and no remap for a year now... as i mentioned, there is some surging and choppy throttle at very low RPM (like cruising through a parking lot barely above idle) but once the revs start climbing there has been no issues at all.
of course you will get the best performance from a proper dyno tune, or at worst a power commander type unit with autotune.... but no concern about losing noticeable performance without the remap, if it loses anything at all, its probably just 2-3hp which you wont notice, its not like a 250 where 2-3hp would be a big difference.
post #7 of 19 Old 11-05-2019, 12:12 PM Thread Starter
There isn't something like a sensor eliminator kind of thing? The one that used to be inside Power Commander boxes.
I've also read something about a "servo" but I don't know what it means. There is something more I should care besides O2 sensor?
age000 is offline
post #8 of 19 Old 11-05-2019, 02:37 PM
It is not a concern on this motorcycle, since the o2 sensor is in the exhaust manifold, so the OEM sensor stays in place.
Yo soy de Uruguay y tengo la misma moto, cualquier cosa que te pueda ayudar, me escribes
Surely you have a power gain of a few hp, luckily your bike is unrestricted, mine came from the United States and was restricted on ETV map… I had to flash my ecu with Woolich.
Guarf is offline
post #9 of 19 Old 11-05-2019, 03:27 PM Thread Starter
You are totally right, I've just checked it right now. One more thing to not worry about
I've purchased a servo buddy for avoiding FI red light.
Que bueno!! Si necesito ayuda con un futuro flash de la ECU ya se a quien preguntar
I don't know if it's restricted on ETV map, something I could do to check it?
Thank you for your help guys! I really appreciate it
age000 is offline
post #10 of 19 Old 11-05-2019, 03:41 PM
But the o2 sensor is not in the catalyst, in the 2016-x is in the mainfold, isn't it? (sorry I don't know how to say it in english the pipes between the catalyst and the cilinders).
The servo is the wire that goes from under your seat to the catalyst, you won't have problems if you free the wire in both ends, I have it in this way.
kroket is offline
