Coolant? - Kawasaki ZX-10R.net
post #1 of 7 Old 08-26-2018, 01:30 PM Thread Starter
Coolant?
Hi everyone, first time needing to change the coolant on my Gen1, is it ok to use prestone 50/50 generic car coolant? I know engine ice is the best, but its not available in my area, and I'm not sure if its even worth it for street duty. I look forward to your feedback, thanks!
Lilbilly is offline
post #2 of 7 Old 08-26-2018, 06:06 PM
SkyDork's Avatar
Well, the Engine Ice wouldn't be the "best stuff". So yes, the Prestone 50/50 will be fine if you're not going to track the bike.
#WordCrimes
SkyDork is offline
post #3 of 7 Old 08-26-2018, 10:43 PM
badexample's Avatar
A few alternative to Engine Ice, Motul Motocool , Purple Ice, Liquid Performance High Performance street bike coolant, Amsoil Dominator coolant boost, Redline Supercool Waterwetter , DEF radiator Relief.
“Ride like you are invisible.”
badexample is offline
post #4 of 7 Old 10-02-2018, 05:16 PM
Srusty's Avatar
07’ coolant amount?
Hi guys, I have just conducted a cooling system flush on my 07’. The manual says it should take 2.9L including the overflow but it seems to only want to take 2L. I conducted the flush and bleed as the manual and some YouTube how to’s said to do it. Any ideas what I am missing?
Srusty is offline
post #5 of 7 Old 10-02-2018, 05:49 PM
michael4012's Avatar
The drain bolt on the front of the cylinders by the headers needs removing because the vacuum will hold all that's in the cylinder and head in, and I expect your not taking the radiator off thete is always some left in there which together would not be far off 0.9lt my guess.
michael4012 is offline
post #6 of 7 Old 10-03-2018, 04:05 AM
Srusty's Avatar
Thanks for that. I did drain through both the water pump and cylinder plugs. So it could just be that the rest is caught up in the radiator as I didn’t remove it. Thanks mate.
Srusty is offline
post #7 of 7 Old 10-03-2018, 06:01 PM
I once saw a guy sucking the coolant out the radiator with a plastic pipe so he didn't have to pull the radiator off......your choice that lol
Low in Coolant in Coolant Resevoir Cuttmosis The ZX-10R 3 03-30-2013 07:18 PM
adding coolant question....where?-(water wetter) MikeP The ZX-10R 18 08-19-2004 05:57 PM
Coolant leak pics - what do you think is causing it? Ghost The ZX-10R 17 08-10-2004 07:57 PM
Need to replace coolant with water - Tips Please! mods2come The ZX-10R 16 06-03-2004 02:15 AM
Coolant leak??? BlackNinja The ZX-10R 19 05-16-2004 08:44 PM
