Gen 4: 2011-2015 C3L1CA's Street/Strip Wanna Be Build Thread - Page 24 - Kawasaki ZX-10R.net
 76Likes
post #231 of 243 Old 04-18-2019, 09:48 AM Thread Starter
C3L1CA's Avatar
Got a bit done again last night in the garage. Got the chain installed, radiator on and most hoses hooked up. The flat pan doesn't use the oil cooler so I have to get a hose from the store today to loop those connections. Got most of the wiring I could all plugged back in and tried to make the wiring lay a bit flatter. When I installed the key eliminator it didn't sit super flat so I got that not looking as much of a rats nest as well as some of the wires for the woolich. Also reran the wide band and got that hooked back up. Need to get a t fitting for the swing arm though as the guy I bought it from left the gauge in the swing arm and I like that idea instead of it being in the tail. That way I can double check the gauge right before the run to make sure I didn't forget to air up or didn't develop a leak for some reason. So I was just going to T to run my air chuck valve and the line to the shifter.
Injector guy said he got my injectors done last night too so I'll be getting those tonight so should be able to button the bike up. Getting closer day by day.
Also caved and sent my airbox to to ejr for the airbox mod. I was going to do it myself but for the amount of time it would've taken me to do it, figured it was worth it to me to just send it out.
Hopefully it starts and runs tomorrow :fingerscrossed:
C3L1CA is offline
post #232 of 243 Old 04-18-2019, 10:28 AM
SpazOnaZX's Avatar
Originally Posted by gaz View Post
first thing, the main thing i want to know after cams degreed, cranked and run thru few heat cycles is compression.
The only thing I hate about this is elevation. My static altitude is 4500+, and my DA is never any better... my static cranking numbers always make me feel like trash, no matter what I'm working on. :(
gaz likes this.
SpazOnaZX is offline
post #233 of 243 Old 05-01-2019, 04:12 AM
ypyk_xau's Avatar
I can tell only props for the airbox mod and the XXL ram intake. Bike is feeling much more violent now. Second gear power wheelies are much more violent than before. Can't tell AFR because my o2 sensor died and waiting for the new one. Butt dyno tells me - hell yeah!
ypyk_xau is offline
post #234 of 243 Old 05-01-2019, 07:29 AM
mpp12's Avatar
C3L1CA,
you would have spent half the money with my mechanic.... doing the mood... I have a few boxes here laying around, you would just have to wrap it...
And yes it takes a lot of work to do that mood.
looks good by the way
mpp12 is offline
post #235 of 243 Old 05-01-2019, 07:57 AM Thread Starter
C3L1CA's Avatar
Good to hear! Hopefully the afr is still in check as it sounds like its getting a lot more fuel!
Originally Posted by mpp12 View Post
C3L1CA,
I almost sent you a PM but then wasn't sure if it'd be too big of a pain in the butt. Good to know for next time or anybody that sees this thread
Bad news on my bike though. I started it on 4/18 late at night to make sure it started without issues as I was hoping to make a track day on the 20th. Bike started and let it idle for a minute and everything seemed good. Finished putting everything back together on Friday and was doing some street tuning and things from my old tune had it pretty close, I threw more fuel up top before making pulls and it was actually rich in some areas. Did a rebuild on the front caliper too as it seemed to be dragging more than I would've liked when putting it all back together.
Went to a good friday thing at church, picked up some fresh 93 on the way home and skipped going out to eat with the inlaws. Came home, did a little rip and it seemed to be quick. On the old hookup it spun in 2nd once it hit the powerband. In draggy i was able to get a 3.93 second 60-130 starting in 3rd. I was kind of glad it broke into the 3s starting in 3rd as seems most guys who are in the 3s are probably starting in 1st.
I was out doing one last log and did a 4th gear pull and just hit the limiter for a split second shut down and at the light right after getting off the highway it sounded like it was making some sort of noise. Got going a bit and bike just died. I was able to coast down the road to a side road and I did start the bike up for a second just to see if it would then shut it down quick as it didn't sound right. All the mods to reduce rolling resistance made it a pretty easy task to roll the thing to the gas station half mile down the road
Think the little guy liked the green and it was growing on me with the side winder too for some reason. At least the guy at the gas station said the bike got a lot of attention and lots of people were taking pictures of it he said. Felt weird leaving it somewhere with no head lights, no key/ignition and no plate lol.
And here is where its been sitting since 4/19.
With working on it every night for a week kind of burnt me out and have some stuff to do around the house. Kind of want to weigh it for fun before start taking it apart. Figure first thing is to pull the timing cover and see if it turns over by hand. Oil in the sight glass still looked good. Hopefully its nothing major, otherwise I might see what I can sell to just get another motor in there and make it to a track day in the fall.
C3L1CA is offline
post #236 of 243 Old 05-01-2019, 08:52 AM
michael4012's Avatar
"otherwise I might see what I can sell to just get another motor in there and make it to a track day in the fall"
Less of the negative waves mirrorony! Im sure itll be something simple it looked like a well worked out build that It will be Fine
michael4012 is offline
post #237 of 243 Old 05-06-2019, 08:47 PM
peterd10r's Avatar
Images: 7
Hi mate hope your well!did you find out what caused the bike to shut down?you did say you got to a petrol station but I'm curious to no!
thanks in advance
michael4012 likes this.
peterd10r is offline
post #238 of 243 Old 05-07-2019, 12:25 AM
thanks in advance
I think most of us are feeling this one mate
post #239 of 243 Old 05-07-2019, 09:07 AM
mpp12's Avatar
men, I have hi hopes for this project.
mpp12 is offline
post #240 of 243 Old 05-07-2019, 09:12 AM Thread Starter
C3L1CA's Avatar
I still haven't dug into the bike yet. The week after it happened just had too much stuff going on with getting ready to go on vacation and I'll be out of town until next week. Tempted to see if I can get a weight on it even though it has a pretty full tank then see if I can turn it over by hand and then maybe pull a plug and see how that looks.
I've been talking about making a few nightstands for our bedroom and tv stand which has now turned into a cool hamper hider. Kind of want to get that stuff done too to get some things off my to do list and don't want a motor open while creating sawdust in case a good chunk of it is savable.
I'll post up what I find, hopefully its good news when I get to it. Fingers crossed.
peterd10r, michael4012 and Kj4rd like this.
C3L1CA is offline
Gen 4: My 2011 ZX-10R Street/Drag Build Thread BOOSTED The ZX-10R 95 10-28-2015 08:40 PM
05 Street & Strip ZX10 TC24 Bikes 4 Sale 4 10-13-2013 07:04 PM
07 street/strip project gazx10 Strip 69 04-14-2012 11:07 AM
BMC race or Street Strip Up2par The ZX-10R 7 10-08-2008 05:45 PM
best street tire for the strip? madnessracing Strip 35 03-08-2007 10:26 PM
