Gen 4: 2011-2015 Bsd ecu flash using Woolich mention upper lower injector balance change - Kawasaki ZX-10R.net
 2Likes
post #1 of 31 Old 03-08-2014, 02:50 PM Thread Starter
abadassbikerlad's Avatar
Send a message via MSN to abadassbikerlad
Hi I see bsd tuning who use Woolich ecu programmer mention they modify upper and lower injector balance, has anyone had them flash your bike and pulled the bin file to examine?
2013 black uk spec gen 4, full akrapovic evo carbon, brembo rcs master cylinder, brembo clutch, ohlins race SCU, woolichracing flashed ecu with stock 02 disabled, ohlins mechatronic rear shock, Suoer corsa Sc2 200 rear smoked hot bodies rear end, Puig screen, s-2 concepts seat hump,Hell hoses, brembo m4 monoblocks samco sport red hoses, samco clamps, evotech oil cap, MWR filter, Putoline syntec 4, Jmt lion battery, nearly all bolts are titanium. 55w 6000k 2.5" Hid projectors.
190.26 hp Din
abadassbikerlad is offline
post #2 of 31 Old 03-08-2014, 03:26 PM
In the Gen 4 the injector balance from the Kawi factory is 70% on lower and 30% on uppers at 100% throttle and above 10,000 RPMs.
It would be easy enough to change it to 50% to 50%.
Sorry cant answer your original post as I don't have my bike BSD tuned or know anyone who has and then has looked at the bin file after BSD tuned and changed it to see what BSD changed it to from stock. Probably not going to be anyone that has done that yet.
SelenaP is offline
post #3 of 31 Old 03-08-2014, 08:42 PM
Joel's Avatar
As SelenaP said about the injector balance.
Generally most people unify the fuel maps which keep the stock offset. So when you add fuel it adds to the total areas. Just makes it easier to tune, you can unify the ignition maps aswell.
The WOOLICH software gives you more than you need to tune, that much flexibility it's crazy.
Only way you can really take advantage is if you have a dyno and the full log box to see exactly what is going on.
Joel is offline
post #4 of 31 Old 03-11-2014, 01:34 PM
zx-sik-r's Avatar
Actually swapping the top to 60 and the lower to 40 will make a few more HP.the fuel from the upper injectors is going to atomize better.
2008 ZX-10r 68" Dime Piece BST wheels
Authorized Woolich Tuner - FLASHED BY SIK
zx-sik-r is offline
post #5 of 31 Old 03-15-2014, 04:54 PM Thread Starter
changing that much ? Stock is 29.7% uppers at high rpm and 70.3 lower injectors, have you changed it on the gen 4 and seen the results on a Dyno?
190.26 hp Din
post #6 of 31 Old 03-15-2014, 06:18 PM
Abo7maid's Avatar
Originally Posted by SelenaP View Post
In the Gen 4 the injector balance from the Kawi factory is 70% on lower and 30% on uppers at 100% throttle and above 10,000 RPMs..
Selena : does this mean that for a consistent tune change between uppers and lowers (not unifying), one should see this ratio in the trim change?
Originally Posted by scout View Post
So, I get a plus one for at least CHECKING the oil???!!!
oh, I did have to add distilled water to the reservoir as it was empty. Thought that odd as it was over full mark when brand new
Abo7maid is offline
post #7 of 31 Old 03-15-2014, 07:19 PM
Sorry, I don't know.
I haven't tested any changes with the injector balance. I don't plan to do so on my Gen 3.
SelenaP is offline
post #8 of 31 Old 04-01-2014, 06:17 PM Thread Starter
I wish someone would test this option on the Dyno,
190.26 hp Din
post #9 of 31 Old 04-02-2014, 04:32 AM
Joel's Avatar
Is it really worth MAYBE the extra 1-2 hp???
I personally think it's not.
Joel is offline
post #10 of 31 Old 04-02-2014, 07:46 AM
zx-sik-r's Avatar
I changed my gen 3 to 70/30 70 being upper.i also tune the WOT through the uppers instead of the lowers.put it this way,my bike runs 128mph with me on it...I broke my arm so my buddy rode it Sunday to test the changes and he's 40-45 lbs heavier then me...he went 126 mph.it shouldn't go that fast at his weight.i believe it made a ridiculous difference for peak power.ill be dyno testing this afternoon
zx-sik-r is offline
DIY ECU Flashing - Woolich Racing FAQ specv The ZX-10R 1733 05-06-2016 10:49 AM
Gen 4: Woolich log box pro ECU programmer all in one abadassbikerlad The ZX-10R 9 01-30-2014 09:36 AM
Gen 1: Woolich reflashed ECU before & after video Balogiannis Performance and Tech 11 10-08-2013 01:33 AM
Gen 4: Woolich Racing vs Guhl Flash??? alex2944 The ZX-10R 5 06-03-2013 05:43 AM
Gen 4: slightly damaged green 2011 left side mid and lower, upper, and upper tail fairings MilkKAW08 Parts, Gear and Accessories 9 09-01-2012 02:52 AM
