Bikes in Imobilizer and Limp Mode - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By metalmechanic9
post #1 of 5 Old 11-01-2018, 04:22 PM Thread Starter
metalmechanic9's Avatar
After oil change, started bike and solid red led, (IMOBILIZER INDICATION)
I bumped the starter a few times to clear oil from filter. I only changed the oil. Dont know if that works.
I read the manual awhile. There is no code.
Went test and about 25 mph it will cut off. Limp mode home.
I disconnected the batt and will go check fuses.
2017 zx 10 rr
metalmechanic9 is offline
post #2 of 5 Old 11-01-2018, 05:05 PM Thread Starter
Ive done a search, GEN 5, IMOBILIZER, LIMP MODE, Nothing
post #3 of 5 Old 11-01-2018, 07:36 PM Thread Starter
Change that,
Its the oil pressure indicator. I didnt notice the oil lamp in the lcd.
post #4 of 5 Old 11-02-2018, 08:21 AM
ddipaola's Avatar
Originally Posted by metalmechanic9 View Post
Change that,
What kind of filter are you using, and did you torque everything accordingly.
Also did you fill the filter with oil before installation and let all the air bubbles come out?
When in doubt... send it!
ddipaola is offline
post #5 of 5 Old 11-08-2018, 12:36 AM Thread Starter
Its good, I didnt change the filter.
Long story.
Brought it back to shop, oil was in by pass mode.
The whole xmsn re-call fiasco was part of this
ddipaola likes this.
Gen 4: Intermittent 3 cylinder (limp?) mode sdiver68 Performance and Tech 9 04-09-2017 05:41 PM
Gen 1: Limp Mode 8K RPM Wallpapereater Performance and Tech 5 07-21-2014 10:37 PM
700hp shelby vs gix 750 , 2012 zx10r in 1k mode, 2012 zx10r in 600 mode whans1980 Pictures and Videos 34 09-12-2013 01:50 PM
Limp mode ?????? cow10r The ZX-10R 2 01-22-2011 10:15 PM
Will ECU go into a limp mode if sceondary actuator is un plugged? garth285 Performance and Tech 12 06-04-2007 09:08 PM
