Gen 5: 2016- 2016 Superstock Build (WERA Legal) - Page 21 - Kawasaki ZX-10R.net
 182Likes
post #201 of 266 Old 01-28-2019, 02:46 PM
ddipaola's Avatar
Oh mama.
Neonmarine likes this.
When in doubt... send it!
ddipaola is offline
post #202 of 266 Old 01-28-2019, 03:40 PM
What's the part numbers for those sweet drilled axle pinch pro-bolts? Where did you source them out? #want
I'd love to see a pic of them installed so I can see how far they protrude out. I keep wanting to get a set of pinch bolts that I can put a pin through, rather than running safety wire each wheel swap. For it to happen, it has to protrude just far enough though. I hope these pro-bolts do that.
Lanister is offline
post #203 of 266 Old 01-28-2019, 06:16 PM Thread Starter
Formerly CLCRACINGAaron
Neonmarine's Avatar
I don't think they will work with an R-clip...still gotta wire it after a wheel removal.
Lanister likes this.
"You must subsume yourself to the bike"-Casey Stoner
"Thereís a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #204 of 266 Old 01-28-2019, 06:59 PM
Thanks for that! I've seen someone on this forum put a few mm thick spacer under the bolt head and it moved it forward enough to make it happen. I do wonder if maybe it would call for a 40mm length or 35mm will still be enough.
Lanister is offline
post #205 of 266 Old 01-28-2019, 07:56 PM Thread Starter
Neonmarine's Avatar
40mm is all about the thread length, so unfortunately this wonít work. You need the socket head redesigned to make it work like you want.
post #206 of 266 Old 01-29-2019, 05:44 PM
I just checked it out with 40mm bolts and those would be unnecessarily long. 35mm would be fine. If you get like a 2-3mm spacer/washer underneath, they would move the heads out enough to put a pin through. Looking at the pic you posted, 2-3mm is most you would need with these drilled pro-bolts.
The challenge now is to find the right type of cotter hairpin that can go through both bolts at once. Maybe I can just make one. Certainly tempting to do as I really hate having to safety wire these things all the time, especially when I'm in a hurry to change wheels at a race weekend.
Lanister is offline
post #207 of 266 Old 01-29-2019, 07:22 PM Thread Starter
Neonmarine's Avatar
Maybe Kurveygirl.com? They have lots of R-clips in various sizes.
post #208 of 266 Old 01-30-2019, 02:24 PM
Did this on my 2012 bike. Small spacers with safety clips, wired to the Woodcraft axle protectors. Found an old photo with stock forks, which shows them alright. Harder to see on the 2016 with the Ohlins forks, with the bolt heads pointing down.
As NeonMarine said, I bought a wide variety of those clips from Julie at KurveyGirl.
Lanister and Neonmarine like this.
CanyonCarver is offline
post #209 of 266 Old 01-30-2019, 02:44 PM
I have all types of clips from KurveyGirl, they sort of work but none are ideal. What I would like to do is not have a clip go through one bolt but a long hair-style-pin go through both. KurveyGurl clips are not long enough to do that, as you can see from the picture. I actually just realized that I can make a clip of my choosing out of a basic large paper-clip. Stand by :)
Lanister is offline
post #210 of 266 Old 01-30-2019, 03:03 PM
FWIW, the clip in my photo does go through both of the pinch bolts...
Tags
gen5, racebuild, superbike, wera racing
Currently Active Users Viewing This Thread: 20 (1 members and 19 guests)
shahrozk
Gen 5: moto316's 2016 ZX-10R racebike build moto316 Track 31 02-01-2018 05:23 AM
Just finished my track build last night. Build album to come, teaser inside streeteg Pictures and Videos 6 09-16-2014 11:26 AM
Gen 1: To Build or Not to Build - Supercharger and Built Motor bobjoe Performance and Tech 12 10-28-2012 02:49 AM
AMA Superstock gone in '09. greeniner Race and Stunt 4 03-26-2007 10:20 AM
WERA Superstock rules yehzx10r Race and Stunt 3 04-29-2006 09:36 AM
