Can't Wheelie My 2014 ZX-10R For The Life Of Me - Page 4 - Kawasaki ZX-10R.net
 18Likes
post #31 of 45 Old 09-08-2015, 10:55 AM
Cyclotron's Avatar
Originally Posted by Driaannel View Post
Troll
I've never ridden any liter bike that wouldn't wheelie when asked, most of them will do it when not asked. No clutching required.
Perhaps the OP should get a passenger on the back and try it again. Be sure to video the whole event.
Cyclotron is offline
post #32 of 45 Old 09-08-2015, 02:08 PM Thread Starter
Alright guys, yes it is aftermarket by lighttech(the chain adjuster) and no this isn't my first bike but my bike before this didn't quite have the power of a liter bike. It was a Suzuki gs500f, so it was Def nowhere near the power of a liter bike. And as I said in the first post, I wanted to learn a clutch up wheelie first because I personally would feel more comfortable and it is somewhat safer. The bike will go up a few inches on its own if I'm ripping through first, but I was looking to achieve more of a slower, controlled wheelie, and hopefully learn to bring it to balance point eventually.
k0622763 is offline
post #33 of 45 Old 09-08-2015, 03:33 PM
SkyDork's Avatar
To each their own, I prefer throttling the front up. I think it comes up smoother and easier and gives you the practice for controlling the throttle like you need to. First gear is fun for me. I have no problem with controlling the throttle even with a quick turn throttle and +2R gearing in first gear. If you can modulate the grip properly, you'll gain the control needed for clutching them up at faster speeds.
Confucius say....man who clutches wheelies, breaks clutch baskets.
Walk before you run grasshoppa! The slow speed stunter stuff in the parking lots you're thinking about is much harder to do than a nice 50-80mph wheelie. At the higher speeds there's more gyroscopic stability from the spinning wheelies and the aerodynamic forces.
#WordCrimes
SkyDork is offline
post #34 of 45 Old 09-08-2015, 09:26 PM
Awwthentic's Avatar
I have the 2012 10R and I will tell you the traction control even set to #1 will not let you pop a wheelie bigger than a couple of inches off the ground. The traction control isnt just for spinning the rear wheel. It helps keep the front end down on hard accelerations. If you take off the traction control, not #1,2, or 3, but OFF, It will come up trust me. With out even using the clutch you can power them up at low/mid RPM's.
Awwthentic is offline
post #35 of 45 Old 09-08-2015, 10:53 PM
A Squids Life's Avatar
Make sure you get plenty of heat into the tyre so you don't accidentally do a rolling burnout instead. Pretty much you accelerate for a second then chop the throttle to make the forks compress a bit then you do the clutching. Alternatively you can press down on the rear brake to compress the front as well, this is good practice as you want to cover the rear brake as it will save you when you get to high. Grip the tank tight with the knees and sit towards the back, arms should be relaxed. At least that's how i do it in second gear around 70 kph.
A Squids Life is offline
post #36 of 45 Old 09-11-2015, 01:10 AM Thread Starter
Thanks guys for all the help. Finally started clutching it up, I'm getting about a foot up before it comes back down. Next step is to chase it out. What worked best for me was standing up and (this may sound weird) but popping the clutch twice. I'm assuming this is cause I'm still figuring out the rpm and throttle control for the wheelie, so on the second clutch up, the bike comes up smoother and easier since the rpms are already higher with the first clutch drop. Anyway I'm gonna keep practicing and start chasing it out, I'll keep you guys updated on my progress. Thanks everyone for the help! Ride safe bike fam
k0622763 is offline
post #37 of 45 Old 09-11-2015, 09:52 AM
bun1t's Avatar
RIP clutch
harobikes167 likes this.
bun1t is offline
post #38 of 45 Old 09-11-2015, 10:25 AM
jr0065's Avatar
Images: 18
Send a message via Yahoo to jr0065
This will not end well.
Gen 5 ZX-10R
jr0065 is offline
post #39 of 45 Old 09-21-2015, 09:01 PM
Full motor , Traction off, go 20 mph , flick clutch in rev to about 6-7 n let the clutch go ..... Got the same bike 2800 miles all stock except exhaust and she stands up likes it was nothing. I wouldn't rush it's not a joke to end up on your ass .....
Anthony Crescenzo is offline
post #40 of 45 Old 09-22-2015, 03:22 PM
harobikes167's Avatar
Originally Posted by bun1t View Post
RIP clutch
LMAO
"Never shoot a large caliber man, with a small caliber bullet."
GEN 3: "Stock"
2009 crf 450r
harobikes167 is offline
2014 zx10r wheelie control question m1ck_zx General Motorcycle Discussions 15 12-04-2014 08:34 PM
2014 zx-10r clutch Funkmaster100 The ZX-10R 25 06-06-2014 06:42 AM
NEW HERE, Looking to get a Gen 4 2014 ZX-10r Derek Short The ZX-10R 13 03-08-2014 11:31 AM
2014 10r? purebusiness1 The ZX-10R 20 09-06-2013 02:27 PM
Life Span of A 10R 5-F Dawg The ZX-10R 14 10-14-2009 01:29 PM
