Why do my forks suck? - Kawasaki ZX-10R.net
post #1 of 7 Old 10-14-2015, 11:40 PM Thread Starter
I picked up a used 09' back in august.
I have dialed in the rear suspension pretty well, still should back out the preload a little. But it's not bad.
The front though. ... it's rough. I took out all the preload and backed the compression all the way out and it still has only like 2" of sag.
The rebound is on 10 out of 14 and is still sluggish. I've watched like a million Dave moss videos and can't seem to get it right.
Maybe the preload springs are too stiff from the factory? Maybe the previous owner changed the fork oil shittily?
(I weight 145ish in gear, 5'10)
It really seems like the adjustments don't do much. No matter what I change, it feels pretty much all the same. Defently not confidence inspiring. I Took a video and will post it as soon as it uploads.
TheDanAgain is offline
post #2 of 7 Old 10-15-2015, 12:24 AM
TechX's Avatar
I would have the forks opened up and freshened up. Then you will know what springs and oil are in there.
TechX is offline
post #3 of 7 Old 10-15-2015, 12:46 AM Thread Starter
Should I do this my self? I would prefer to do all the work on this bike (except for valve adjustments)
Maybe If I downloaded a copy of the service manual?
post #4 of 7 Old 10-15-2015, 01:02 AM
Crazi's Avatar
Second vote for having the oil changed and the forks rebuilt. Whats your intended use for the bike?
Racetechs website will tell you what the stock spring weight is and recommend a spring for your weight and riding style. If the recommended spring is significantly lighter than factory, there is your problem.
If you can rebuild the forks yourself, you will definitely save some money. Just for reference, getting my forks done over the winter on my 13 with around 16k miles on it. I didn't realize how much effect fresh oil had on the suspension until 4 or so years ago on my gen 1. I'll be changing my fluids every other year from this point forward.
05 Z1000 - Traded
05 ZX12R - Stolen
04 ZX10R - Going to be sold soon. New bully on the block!
13 ZX10R - Getting abused...
"It is the mark of an educated mind to be able to entertain a thought without accepting it"
Crazi is offline
post #5 of 7 Old 10-15-2015, 03:20 AM
renais's Avatar
I'm about 155lbs and had to change out the stock springs for 0.9's. Stock front end felt like treacle. Found there was too much oil in there from the factory so now have 110mm air gap. Preload is still backed all the way out for 25mm free sag, rebound also. Compression about 6 clicks out. I had to fit a 105N spring in the shock though
Also worth checking is that the fork legs are not pinched causing stiction
next time I change the oil I might try higher viscosity
renais is offline
post #6 of 7 Old 10-15-2015, 07:40 AM
SkyDork's Avatar
To what the others have said.
At 145lbs, you're going to need new springs. You're too light for what the stock springs were designed for. The oil could stand to be changed since it's an unknown at this point. But unless the previous owner way overfilled it, it's not likely to be causing your issues with the sag. The damping certainly would be changed by the oil weight though. So if it's slow to react, lighter weight oil and lighter springs are probably what you're going to wanna do.
#WordCrimes
SkyDork is offline
post #7 of 7 Old 10-15-2015, 10:34 AM
TechX's Avatar
Forks can be difficult to do yourself unless you have all the special tools needed to do the job.
TechX is offline
Gen 3: TRADE - Your BLACK forks for my GOLD forks! I2aMpAnT Wanted: Buy or Trade 5 06-10-2015 04:07 AM
Gen 4: Trade my 2012 forks for your 2011 forks - Bay area GILBY Wanted: Buy or Trade 3 02-26-2014 02:15 PM
Gen 2: SE Forks 06-07 forks $190 Shipped!!!! 08zx10rny Parts, Gear and Accessories 8 11-11-2011 08:44 PM
Ohlins Road&Track forks VS Superbike forks? JLG0987 Performance and Tech 2 01-05-2010 09:42 PM
Does anyone know if the front forks can be swapped with forks from another model liljunglist2 The ZX-10R 2 02-04-2005 01:39 PM
