What's too much weight. - Kawasaki ZX-10R.net
 1Likes
post #1 of 16 Old 08-19-2015, 11:39 AM Thread Starter
Elantrajoehasazx10r's Avatar
I had the shop do a front and rear tire. He put 1 oz on each side of the rim in on spot on the front rim so there's a total of 2 oz there. I'm getting a bad shake and vibration at 85 90 is it because he used to many weights on the tire? I'm
Going to call later today and complain. The shake wasn't there before I brought them the bike.
Elantrajoehasazx10r is offline
post #2 of 16 Old 08-19-2015, 12:12 PM
TechX's Avatar
tires should be rebalance for sure. I would be there to watch what he's doing. Tires can be very different I have had tire's that required no weight at all to balance them and other's that take a few oz to get correct.
TechX is offline
post #3 of 16 Old 08-19-2015, 12:29 PM
Yep. Re-balance needed.
dmac28 is offline
post #4 of 16 Old 08-19-2015, 01:54 PM Thread Starter
I called the shop they said they have a machine that does it but I'm not so sure on that. He tried selling me tire beads at first and now i think he's giving them to me for free.
post #5 of 16 Old 08-19-2015, 04:33 PM
TechX's Avatar
I would not use tire beads. They should be able to balance the tire without beads. If they tell you they can't I would look for another place. I have never had to use tire beads to balance a tire. Sometimes a tire is made so badly it cannot be balanced my friend had that problem with a new dunlop Q3 its a defect from the factory. Dunlop had no problem taking it back and giving him a new tire. Your's doesn't sound that extreme they should be able to balance it with just wheel weights.
TechX is offline
post #6 of 16 Old 08-19-2015, 05:14 PM Thread Starter
I agree they should be able to balance the tire with weights there should be no excuse as to why they can't buy I thought that going for the tire beads would be an upgrade from weights. Have you tried the tire beads before? Now I'm not sure what to do.
post #7 of 16 Old 08-19-2015, 09:07 PM
TechX's Avatar
I have not used them but I have never had a tire that couldnt be balanced the normal way. I did a forum search theres a couple of threads about them some had the beads turn to powder inside the wheel. The concensus was that their not very good.
TechX is offline
post #8 of 16 Old 08-20-2015, 01:45 PM
nakedinseattle's Avatar
do NOT use tire beads. repeat, DO NOT use tire beads.
2oz of weight is meh as far as that goes. it's just not balanced properly. should be done by hand, not machine.
White Fang likes this.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #9 of 16 Old 08-21-2015, 01:26 PM Thread Starter
Yup tire beads are a no go. I just read hells razor's review on them and traditional weights is what I want. Now will it help to mention that these are the first set of tires I'm replacing on this bike they went on at 4,3xx miles.
post #10 of 16 Old 08-21-2015, 02:49 PM
White Fang's Avatar
First off, what type and brand of tire? Some tires have known issues. Some are more prone to shake.
Beads are ridiculous, NEVER use any kind of product that goes inside the tire to balance or seal it.
That wheel needs to be rebalanced correctly with a properly calibrated wheel balancer.
This happens sometimes. Next time try a different shop and ask how they balance.
White Fang is offline
What is this and much could it weight??? barnes The ZX-10R 17 10-02-2007 01:35 PM
'04/'05 weight vs. '06 weight zeta xray The ZX-10R 75 11-25-2006 10:29 AM
Weight truebudo Performance and Tech 5 11-07-2006 11:37 AM
Weight truebudo The Out House 4 11-07-2006 11:17 AM
