What year front forks are interchangeable with 2012 zx10r - Kawasaki ZX-10R.net
post #1 of 5 Old 08-18-2013, 02:52 AM Thread Starter
As the question states what year front forks can be used or are the same as the forks that come on the zx10r 2012. Can the zx6R be used?
jimdchico is offline
post #2 of 5 Old 08-18-2013, 07:44 PM
custom1140 is offline
post #3 of 5 Old 08-18-2013, 09:19 PM
I am almost 100% positive That the 09-2012 forks will fit in the triples and I am 100% sure that the wheels will work with those forks. The internals will be much different than the 2011 and up zx10 forks though. Which will hurt you in a road course application because of the bikes weight, weight distribution and geometry. You can also swap triples and fit many other forks if you wanted to go that route. But It would be easier to just bolt in some zx10 forks and ride.
badkawi is offline
post #4 of 5 Old 08-18-2013, 09:21 PM
I ment to say 09 -2012 zx6r forks
badkawi is offline
post #5 of 5 Old 08-18-2013, 09:22 PM
StZixxer's Avatar
Do you need forks?
Sent from my Nexus 7
StZixxer is offline
ZX10R front forks 1000 cc LT The ZX-10R 3 04-09-2013 01:33 AM
Front Forks: Are the 07-08 ZX10R the same? JDSZX10R o8 The ZX-10R 6 02-07-2011 02:20 AM
Interchangeable front wheel zx6R-zx10R seti Performance and Tech 0 10-12-2010 02:08 AM
06-07 zx10r front forks garth285 Parts, Gear and Accessories 2 04-13-2010 05:09 PM
zx10r forks interchangeable? ezmony23 The ZX-10R 4 11-04-2005 09:06 PM
